Xiaomi Redmi Note 3
i1magic
Bought the Xiaomi Note 3, remove camera due to work requirement. I had a glass screen protector over it but didnt get the case ..
3rd day and i drop the phone (Knee level), immediately the screen inside crack and the phone bent ...
Heart pain, went sim lim to ask and they quote 120 dollars ...
I think i can throw away the phone and get Asus max instead ...
:vijayadmin::vijayadmin::vijayadmin:
Wah .... but from what they showed on this video :
Knee level height drop should be "sub sub water" for Redmin Note 3 leh.
kelvinti
Hahaha! You really believe the 2 chaps; Hugo Balls and Kumar Vijaya?:D:D:D=:p
tech_oasis
Please define 'global rom warranty '.
First is export set. So no LOCAL or INTERNATIONAL warranty.
And, there local set why buy export? Saving not much when comparing.
Sent from Samsung Galaxy S5 (RestructionRemix ROM) using GAGT
Based on my limited understanding, heard china sets of have their on rom and no google play store. Global rom have google store and more stable.
:( local set now challenging to find stock, can find export sets on lazada. Savings around $50.
i1magic
Battery life seems to have improved with the latest update. With 14% remaining
Sent from Jiak Liow Bi phone using GAGT
Wah lau .... how come your battery life is so good?
Mine with SOT 4h15m, over 1d 8h 13m, battery left 23%. Don't think my 9% can give me another SOT of 5hrs.
Depends on usage. For me my main use of this phone is surfing, streaming and a bit of casual gaming most of the time
Yes. But 9hrs of SOT is still 9hrs of time that the screen is ON right?
kelvinti
Well... Screen on (as in SOT value) but do nothing, then SOT value can be for 5 days.
Haha!
Thank again..
ceestudent
How is 7.3.5.0 update so far?
Have not update to this version yet after reading some complaint few weeks ago.
dralf
Just got the china set. Spent about 2 hrs trying to figure out how to flash to global rom.
Is there something done wrongly with my flashing? There are tons of themes in the china rom. But it is very limited in the global rom.
There is zero theme in the cartoon category...
Btw which keyboard and browser are u all using?
Then this phone looks nice without casing. But is quite painful when holding it for prolonged use. How many of u are using without casing?
kelvinti
This 7.3.5.0 is a Stable version compared to last week's Beta!
Personally, so far so good! Everything works fine. No degrading of performance and battery life or of any sorts.
Just Me
Rooting the phone should enable downloaded themes to be usable after some miui tweaking
kelvinti
China set with SD chip or MTK chip?
If it is a SD chip, then super easy to flash Global ROM in less than 10 minutes to make it a "locaL' or Pro set whatever you wanna call it!:s22:
MTK chip then a bit maifun I think..:s11:
Keyboards wise, I use SwiftKey for English and Google Piyin for handwrting Chinese.
Browser is non other than the awesome Chrome!
As for casing. Go buy the Clasy transparent thin TPU case from MobileSquare at just $10. (Not promoting for them. Just that they are the only shop that I know is selling the Clasy case).
A very nice casing that keeps the good look of your phone visible to yourself and othera. :)
micgoh
Why did you get the china set? Local set is more worthy because of SD chipset and support
ZhuTou!
Why u use 2 keyboard?
Swiftkey alone can type both english and chinese lol
