Xiaomi Redmi Note 3
ZhuTou!
Thanks for the pics but I meant non-silent mode. Even when my vibration toggle is off, the phone still vibrates
So i just want sound but no vibration. Is that possible?
Silent and vibrate toggle
Dun tap on it
Leave it "no light"
treeskull
If you are concerning bout WhatsApp, u can disable vibration in the settings as of below
Sent from 你是我的小啊小苹果儿怎么爱你都不嫌多红红的小脸儿温暖我的心窝点亮我身命的火火火火火火 using GAGT
kelvinti
MIUI8 China rom. Nice but I got headache installing apps from Google PlayStore with all kind of permission errors and requirements... LOL..
kopi22
I did not know.
Thanks for the tip...
You can rearrange the toggles too so that those frequently used ones will be more visible on the first few rows when pull down the notification shade.
Oinkize
To rearrange I am aware. But to scroll down is something new to me...
SpeedWeed
my experience with the phone so far has been pleasant
yes i went to buy it at challenger instead of #$@$@ trying to fastest finger first on their website
smooth experience camera is decent
but at the price point. cannot complain.
unfortunately our market is small so they do alot of the limited sales **** which pisses me off alot
SpeedWeed
btw any kind brother here can advise me where to find original accessories for xiaomi
I want the charging cable as i gave my spare to my helper and my other one is almost dead.
thank you :o
Starbutt
Question on the auto brightness adjustment. I like the fact the screen is readable in bright sunlight with the Auto Brightness enabled when driving in the open. However when I drive inside a tunnel, the screen becomes so dim that I have to disable auto brightness. Is there anyway to really make the adjustment really auto so I do not have to toggle the setting when driving in and out of tunnels?
Sent from Xiaomi MI 4I using GAGT
PC-User
The auto brightness cannot handle drastic changes as it doesn't have multi-point adjustments. You can try Velis Brightness Control.
