Xiaomi Redmi Note 3
kopi22
Awesome! I've read that some pple needed to format it in a special way...does the Samsung card need to be done that way?
Using Samsung 64GB here too and no issue. But will need to format the card in Fat32 instead of the more common exFAT. That being said, you will not be able to format 64GB with the Windows format utility. You have to look for 3rd party tools to do that. MIUI don't seems to recognize exFat, unlike Samsung. So with FAT32, it means you will not be able to transfer >4GB of data file to the phone. Not an issue for me so far unless I'm copying a 4GB FHD movie.
amazingone
鬧特4 ?!
Sent from Sumire using GAGT
i1magic
How do you all move one picture file from one folder to another? Which app do you use?
blade39
Does anyone has any issue with their fingerprint sensor with the current firmware?
I am sure I placed my finger properly on the reader when unlocking and the phone just vibrate(mean wrong fingerprint).
Sometime it work but most of the time it doesn't.
hyper_megaman
re-register your fingerprint?
some people register in 1 position, but then commonly use it in another position
just hold the phone as u would normally when u re-register, see how it turns out
kelvinti
So, tio conned liao! =:p
No MIUI8 beta for RN3 at this initial stage! :(
Chey! :vijayadmin:
