Xiaomi Redmi Note 3
TitanSmall
no leh... is the stable rom
i saw somewhere if stuck in bootloop then press power button for like 5-10 sec then it should be fine
cannot leh.. :(
both rom i never envounter that ba.. bootloop usually file error.. is yours local or export set? if export then might be a bad rom causing it that is flashed by the seller if not china rom
is a local set.. intending to go service center tml... but hope i can solve it tonight
i1magic
With 13% battery remaining
How come 10hrs+ SOT and only consume 35% of the battery.
Mine, now 2h4m SOT and already consumed 18% of the battery liao. Are you on Auto brightness?
TitanSmall
If you can enter Fastboot mode (Total blank screen) , then you can miflash it using Fastboot ROM, not Recovery ROM (.zip).
thats EDL?
my fastboot got this andriod figure with FASTBOOT at the bottom.
not totally black
Tech n Travel
thats EDL?
not totally black
yes thats the fastboot mode.. u can use that to reflash and wipe all data.. hopefully no important data inside.. x=
later u wipe your dad's pawn.. he angry and pwn you.. :s13::s13::s13::s13:
TitanSmall
muwahhahaha... then too bad for him la...
i try to use miflash.. then it keep saying 'The system cannot find the file specified.(0x80070002)'
giving up liao...haiz...
DigDub
the folders and subfolders which the file is in cannot have space in between for the folders name.
tanchoo1
You have to choose the "Flash All" option. Note that ALL of your data will be erased, for sure.
kelvinti
You must browse all the way through the folders until you are inside the "Image" folder before you can click the Refresh and then Flash the Fastboot rom.
Make sure you select "Flash All" option at the button of the Miflash too.
Give it a try.
TitanSmall
thanks all for the encouragement.. decide to do it again..
and i realise... i didnt unzip the tgz file.. thats why... LOL im such a kum gong
now can flash liao... booting up now...
thanks all!!!!!!!!
kelvinti
thanks all!!!!!!!!
Hahaha! :s13:
Aiyo! Blur fried oyster! :o=:p=:p
kelvinti
Anyone else finds 7.5.3.0 has poorer/totally different RAM management?
7.5.3.0 is the worst rom...a hybrid of MIUI7 and MIUI8! Rojak rom sia! :(
You are better off to either downgrade to MUIU7 7.3.7.0 or upgrade to MIUI8 Beta 6.7.29! :)
joeidle1
Anyone knows how often does Xiaomi website restock their phones? Am thinking of getting a Redmi Note 3 (Grey, 32GB) and it seems like the website is taking forever to restock
Tech n Travel
u can get from me xD just as new used only a few days by a lady user.. *ahem*
exactly the same variant u want.. local grey 32GB and at a slightly cheaper price xD
best of all u can get it tomorrow !!
