Just Me
- Jan 1, 2000
Nope. But my sot varies. All time best was 10 hours. Then the last 2 usage after a full charge could only get a little over 8 hours and 6.5 hours average. I suspect the battery calibration isn't very accurate. Anyway, if I can get slightly less than 8 hours most of the time it's good enough for nowAre you using the fingerprint sensor?
Quote :
It is known bug and already reported it will be solved in next update ,
Fingerprint sensor not letting CPU to deep sleep, for temporary solution you can disable fingerprint lock till next update.
Sent from Jiak Liow Bi phone using GAGT
