Xiaomi Redmi Note 3
FinalTidus
My battery life after new update.
Better but should be even better.
Oh man the battery life really sucks! :s22::eek::(
Looks like I will be sticking to my 7.3.2.0 ROM for a while. :o
FinchGuy
Thinking of getting this phone and got a suaku question: When phone is in sleep mode, need to use the fingerprint sensor to wake it up? TIA.
kelvinti
Enough tasting the MIUI8 Beta..
I'm back to MIUI7 Stable awaiting for the official release of MIUI8 Stable at the end of August. :)
[/URL]
kelvinti
Humm...
Either use the fingerprint sensor or power button to wake it up. :)
i1magic
This is first full charge and use after flashing the latest update. Probably see better battery life later.
Can post your battery life for your phone on 7.3.2.0?
Another thing is that I find the picture quality taken by the phone is better on MIUI 8, anybody can confirm?
i1magic
Humm...
OIC. Was wondering how to wake it when mounted in holder in car. Thanks.
If you press the power button, you'll still need to key in the PIN or slide pattern to unlock the phone.
Just Me
Pokemon go uses GPS and data a lot. So it isn't surprising
Sent from Jiak Liow Bi phone using GAGT
jskywalker
Export Set Flash Global Stable ROM
Am looking for a Redmi Note 3 pro local set, but MI Singapore is always out of stock, actually many things are out of stock on the website....
Is it possible to buy a Redmi Note 3 pro export set flash it with Global stable ROM without rooting the phone ?
maxlovely
Answer this question many times already.
Yes, you can flash the device to global rom using edl mode, no need unlock or root.
FinalTidus
Just asking.
I have been using my old Samsung 1A charger for my Note 3 instead of the 2A supplied charger from Xiaomi.
This is because I don't like the quick charge feature which will really heat up my phone a lot during the early stages of charging. And cause the battery to heat up and shorten the lifespan.
I understand that 1A charging will extend the charging time. I am fine with that as I prefer to charge longer than charge faster but heat up the battery too hot.
But will this cause an overcharging problem for the battery? Meaning that the battery might take in more charge than it usually does for the default charger?
disastrous
The set I bought is using China rom, to flash to Global rom .. do I download the .zip or .tar version? Seems like got 2 versions and should I use PC Suit or Mi Flash tool to flash?
kelvinti
Download the .tar and un.tar it then flash it via MiFlash! (Not PC Suits):s22:
kelvinti
MIUI7 folks,
There is an update to 7.5.4.0 now to random users only!
