kelvinti
- Jan 5, 2009
Look for the Hexa-core.![]()
Cant find on lazada. cheapest i found was
http://www.lazada.sg/xiaomi-redmi-note-3-pro-snapdragon-32gb-gold-export-6346316.html
228$
Transparent TPU case turning yellow.
Any recommendation for a thin case that do not add bulk?
Am looking for a Redmi Note 3 pro local set, but MI Singapore is always out of stock, actually many things are out of stock on the website....
Is it possible to buy a Redmi Note 3 pro export set flash it with Global stable ROM without rooting the phone ?
received update notification for 7.5.4. think I stick with 7.3.6.![]()
Is there a pro version?
Mine is grey...:-(It depends. If you have a gold phone and even the TPU tunred yellow, it blends well with my Gold RN3.
You can even tell the case has became yellow lor! Haha!
It won't cause any overcharging as the the device is smart enough to handle that. Very easy to check for yourself. When the device is charging, the charger should be warm or slightly hot. When the charge hits 100%, leave it plugged in and remain ON. After a while, touch and feel the charger. It should be cooling down meaning charging is stopped.Just asking.
I have been using my old Samsung 1A charger for my Note 3 instead of the 2A supplied charger from Xiaomi.
This is because I don't like the quick charge feature which will really heat up my phone a lot during the early stages of charging. And cause the battery to heat up and shorten the lifespan.
I understand that 1A charging will extend the charging time. I am fine with that as I prefer to charge longer than charge faster but heat up the battery too hot.
But will this cause an overcharging problem for the battery? Meaning that the battery might take in more charge than it usually does for the default charger?
How many variations are there in total? I'm thinking of getting one set from lazada but I'm confused about the hexa octa core thing
can the redmi note 3 support 3G?
still on 12gb 3g. thx all!
Just got it from challenger! Btw guys, there's a sticker on the back. Can I take it out? But it seems like it is stick to phone. I think will leave behind some marks if I tear it out.
Cool! Welcome!
That sticker can be teared out and then just use a wet cloth to clean away the sticky remanding! Very fast one! No problem one!
I did that too!![]()
