twinklingstars
- Aug 2, 2006
i can only detect my house wifi on 2.4ghz but not 5ghz.. but my phone is still not connecting to the wifi..![]()
anyone can help???
anyone can help???
anyone can help???
Battery like dat means end of life soon, or motherboard problematic.
Your budget of $600 is a lot haha. RMN3 is one of the best phones and for its price, it is definitely worth it. Fast & battery life good. Camera is not the best indoors or low light but still good.
Previously I used the Samsung note 4 also...same like u..battery drop like BMW drink petrol...
Changed to this phone...ah...feels so much bettet
Anybody managed to get "Fake GPS" (aka Fly GPS) to work on RMN3?
I tried whatever but still couldn't get it to work in my RMN3.
Unhide your 5Ghz SSID thru your router setup page if you have not done so.
Try to see if your phone can see the 5Ghz SSID?
Happens once my tablet unable to connect to 5Ghz SSID even when I entered correct SSID & password.
If can connect to the 5Ghz SSID, then just go back router setup page to hide it again if your worry pple sees your SSID. After phone connected once, it shld auto connect the next time.
Otherwise, dunno simi problem liao.![]()
It force closes..In what sense not working?
It force closes..![]()
Downloaded both miui_HMNote3ProtwGlobal_6.9.8_bf083f0252_6.0 and miui_HMNote3ProGlobal_6.9.9_f26648d8b5_6.0 and follow the instruction http://en.miui.com/a-232.html
The phone just showed : -
Can't verify update - Couldn't verify update package
Because flygps need marshmallow. MIUI 8 global stable only 5.1 niaYes. After we installed it. Open it and it "force close". After we do all the "Allow pop up" stuffs, still force close. After doing whatever that we have to do and can do, still force close.
I'm using the global beta on Android 6. Doesn't work either for fakegps.Because flygps need marshmallow. MIUI 8 global stable only 5.1 nia
Sent from Xiaomi REDMI NOTE 3 using GAGT
Wah is it? Sian Liao lol, see my colleague Samsung fly until song song.I'm using the global beta on Android 6. Doesn't work either for fakegps.
Sent from Pikachu using GAGT
Off already, but it worked when I was running cm on my redmi note 3 previously.Wah is it? Sian Liao lol, see my colleague Samsung fly until song song.
Got try turning off MIUI optimisation in developers option?
Last time the low end phones not that good. With the SIM only or MySIM type plans and excellent phone options like RMN3 without plan, this is probably the most value for money mobile line ownership. Ard $40/m + RMN3 for <$200 prob gives u 99% of everything u need.
Of coz there will still be $1000+ iPhone and Samsung owners with 24m contracts with warranty that make sense to those who want to own the best.
