Xiaomi Redmi Note 3
runeruin
I buy from official xiaomi tmall urh, picked the 16gb version as it will be serving me as a spare phone. :) lazada cheaper if stack discounts. :)
i see..
i went to check out again,apparently theres different links and must click through from the banner to see the next sale time
the 32gb link is hiding somewhere..
Devilsire
just gotten my gold note3 32gb/3gb for ~$250+, loving the build :D
was trying to monitor the battery, however i noticed the battery capacity from file & profile (Battery monitor app by 3c) shows just 3020mAh / 3060mAh? going thru the inbuilt settings & info doesnt reveals the actual mAh too.
XasakuraX
any tsum2 players here? is it just me or does tsum2 lag very badly using note 3? mine is the 3gb ram version btw. usable ram is usually ard 1.3gb.
Devilsire
Is rn3 IR sensor proprietary to xm products or universal with learning capability from its IR remote control app?
Sent from my phone using GAGT
Its the later. Basically it have a inbuilt app where u firstly select type of device with tons of major/china brand option (one can actually anyhow choose the brand). Once selected, it'll prompt with several attempts to pair the correct signal to the device till it responds & save the setting.
A very handy feature which im using for multiple fans, aircon, tvs etc :s13:
JivBunny
Generally tsum tsum is quite laggy on most android machines for some reasons.
That's why I only play it on my iPhone.
But nowadays nothing much to play liao except the Xmas tree ornament. Waiting for new tsums
XasakuraX
My belle animation very lag, always end up lag n less skills activated then i sianz liao.
My z2 thou gt laggy but not as bad as note 3 :(
Devilsire
For those with delay notifications, just sharing some steps to minimize it:
1) Settings - Notifications - Manage notification - Select app - Priority ON
2) Security - Permissions - Autostart - Select app ON
3) Security - Data - Restrict data usage - Select app - Data/WLAN on
4) Security - Data - Data saver OFF or Deselect apps
5) Settings - Additional settings - Battery & Performance - Manage apps battery usage OFF or Deselect apps
6) Menu (left button) on home, hold app icon & pull down to "lock" app
7) Reboot phone daily, and start those daily app manually
and yep its mostly due to MIUI system which allows multiple customizing/optimizing thats affecting all the push notifications
XasakuraX
Is m1 4g slower than singtel? Mine seems slower, but dunnoe isit becos of telco or sim2 slot will be slower?
cscs3
wow, reboot daily. Miui is crazy!
Are they going to fix it?
