Xiaomi Redmi Note 3
batniss
Just ordered on LAZADA using the Standchart $50 off promotion.
Worked out to $251 for the silver version.
Gold available too.
Actually thats even cheaper than getting it direct from Xiaomi on Tmall!
$298 now... minus $50.. will be $248.
wondering if i should get it as well.. but like have problems with the miui right?
cscs3
Miui is forever problem. I would hold on till Global rom is released.
hydeyoshi
Im still using redmi 1.. Dunno wanna change to redmi note 3 now ornt sia.. Is the notification prob very jialat?
jedi5diah
i went holiday with redmi note 3 and already know all the work arounds for it, please feel free to ask me dont need global rom to enjoy
Bryson
ya me wondering buying Redmi Note 2 locally or get Redmi Note 3....
I was in your situation yesterday but decided to go for note 2 locally instead. Warranty and local support is a plus for me. Unless you really need the finger print scanner and bigger battery and ditch the expandable memory, go for the note 3.
halocast
see if u value support and warranty? unfortunately their warranty not global.. if it was.. it would be good man.
its only this that's makes the difference.. maybe global rom if u nitpick haha :o
jedi5diah
there won't be global rom until it launch in india or sea
yup, the biggest down side is no sd card
the hardware is solid for this price
flash the dev rom to have most things "fixed"
