Xiaomi Redmi Note 3
ku1234
Yes, I did a check and it says 406.93MB used :(
But one thing I noticed is that I accidentally left my phone on (playing music) before bedtime and the warning SMS was sent around 5am. But I didn't turn on mobile data before I go the bed. I did turn off my home Wifi though.
Could the music or some other apps in the background automatically switched to use mobile data when WiFi was off?
Even then, the Redmi note 3 should reflect the actual usage, isn't it? (*puzzled*) Don't know if it's M1 or RN3's problem now.
numbers
just bought redmi note 3....SIM card not detected...sian...anyone got this problem too?
Just Me
Anyway, just a minor shoutout. If you want good battery life (Maximize Screen On Time) stay on MIUI 7, 7.3.6.0, otherwise can upgrade to the latest for all the new features.:s12:
Using global beta rom with MM can already get me 8 hours+ usage for every charge.. I think that's pretty sufficient considering my Ipad mini 2 is 9hrs+ SOT even after more than 2 years usage..
amazingone
FYI, 279 is for the 32gb model
http://www.lazada.sg/xiaomi-redmi-note-3-2gb-16gb-gold-9223859.html
http://www.lazada.sg/xiaomi-redmi-note-3-2gb-16gb-grey-9269420.html
Sent from Sumire using GAGT
bladez87
any idea why my phone charging very slowly? using the same power plug and cable on my lenovo k3 note, it can get up to 1700mah, but for xiaomi redmi note 3 pro, only 900 mah.
p105ss
Why when include discounts 180+ (3GB+32GB) version no one buy?
now say promo 199 for the (2GB version) everyone wanna chiong and disappointed when cant find!?
Audiology93
I believe the 3/32 at 189 was an export set. I bought 1. Used for a few days and sold it and then bought the 2/16 local set.
Have u tried a different cable and charger? Mine's charging at 5.2V 1.9A with my anker 60W multi port charger.
Sent from Samsung SM-N930F using GAGT
bladez87
i having difficult unlocking the redmi note 3. says that my device is not supported by mi unlock?
how does it recognize my device? by sim card or plugging into computer via usb?
hehuafa
Bro Audio,
May i check with you the 2ram/16gigs rom local set compare to the 3/32 one any major diff feel when using ut. I mean us there any sense of lagginess compare to the 3gigs ram set ?
Hope you can share your personal experience since u were having the export 3/32 sd set n now a local 2/16gig rom set.
Thanks,
