Xiaomi Redmi Note 3
Audiology93
Bro Audio,
May i check with you the 2ram/16gigs rom local set compare to the 3/32 one any major diff feel when using ut. I mean us there any sense of lagginess compare to the 3gigs ram set ?
Hope you can share your personal experience since u were having the export 3/32 sd set n now a local 2/16gig rom set.
Thanks,
Personally, no diff. I usually have at most 3 apps open in the background(WhatsApp, chrome and maybe 1 game) and that's about it. I'm not a heavy gamer. The only 3 games I play are CoC, Clash Royale and Pokemon Go. Unless you have 5 or more apps in the background, I doubt there's much difference between 2/16 and 3/32. I do have a 64GB microSD card inside for all my videos and music.
Sent from Samsung SM-N930F using GAGT
Niaoson
Anyone tried using the online ROM for the 2GB/16GB model?
Tried flashing and it seemed to work but the SIM card cannot be detected?
Does it have to do with the ROM? :s22:
hehuafa
Noted Tks 👌👍
Starbutt
knightcover
got pic?? maybe u get redmi note 4?
I am really shocked. So disappointed cos I prev had a good experience with SmartCell.
i1magic
I have a super ridiculous problem. Bought a RMN3 Grey 32GB from Smartcell, and found that it is PHYSICALLY LONGER than my gold RMN3. I believe i might have gotten a counterfeit set. Any help?
Sent from Xiaomi REDMI NOTE 3 using GAGT
Could you power up the Grey Redmi Note 3 and confirm the model?
If the seller has good track record, it shouldn't suddenly screw up one right?
hachi
Hi guys, just brought an export set 2/16. May I know how what setting do I need in order to play pokrmon go? Down grade from my export mi. Max as I find it too big and using China rom, previously don't have problems with export mi max using China rom.
Anyone can help, thanks.
Oinkize
There should no be any additional settings required to run Pokemon go on note 3.
What issues are you facing?
kst
Manage to hoot a Note 3 Pro at $126 after shop 15% disc and Gift card ($100 for $97).
Good deal ;)
