Xiaomi Redmi Note 3
clay9477
Redmi Note 3 officially out of production as well. Removed from China Mi Store listing already.
happyko
I'm currently using Redmi Note 3 Pro on Global ROM (after my OnePlus One suffered bootloop and unable to unbrick despite trying the few methods found on-line).
I bought it after reading the thread here,
3GB RAM 64GB ROM, support external SD, snapdragon and the attractive $188 sales.
Very happy with the battery and performance after one month plus of usage.
This is really a cheap and good phone to me (for below $200).
As such, I also bought a second Redmi Note 3 Kate Special Edition as spare.
Now that it is already EOL, just wondering, what will be the my next 'Redmi Note 3' replacement... :s8:
clay9477
Nokia Android, if it is a success.
Oinkize
Redmi note 4?
amazingone
Maybe the Redmi Note 4X haha
Sent from my Xperia using GAGT
Techno Pride
I'm using Nillkin case. It's a hard cover that covers only the back. Fits very well.
The iPaky and MSVII (slim) back covers don't fit well. Loose. Don't buy those.
Got from eBay.
PC-User
Thanks. Anyone got cases to recommend as well?
Sent from Xiaomi REDMI NOTE 3 using GAGT
I'm using this brand... Cheap and good looking.
Techno Pride
The ipaky one for Redmi Note 3 looks different.
Anyway, this is a 2 piece set.A back piece of rubber and a plastic piece to hold it in place. The plastic is loose on the side.
getsetgo
Redmi Note 3 protective casing and tempered glass
I bought a Redmi Note 3 from Mi store
size: 152mm X 76mm X 8.65mm
Anyone know where to get a casing and tempered glass that can fit nicely.
Thanks.
I bought a HD tempered glass but length shorter by 4mm.
ceestudent
Thanks.
Do you mean SG mi store sell the kate special edition version now?
You can search the case and tempered glass with keyword redmi note international kate at aliexpress.
twobellyflops
Anyone know where to get redmi note 3 pro , local set? Went to singtel and was told no stocks for a month alr.. Is it available at the physical store at suntec? Or what's the price at M1 and starhub? Thanks
amazingone
Their Suntec store should have, or else you can go to Challenger stores or online at lazada.sg/mistore
