Xiaomi Redmi Note 3
Hakaima
Anybody having issues with updating playstore apps after the last major miui update? Nowadays all my apps are stuck at pending download. Sometimes lucky will actually start downloading. Emptied cache also no use.
System apps still can dl as per normal
Posted from PCWX using the depths of my bowels
carboy00
Anyone using TPG on Redmi Note 3 SE? Can't seem to get VoLTE working. :(
Sent from Xiaomi Mi A2 using GAGT
danerine
Yeah me 2. I have only manage to get the data working but VoLTE is not working on Redmi Note 3 for TPG even after keying the code to disable carrier check.
Shutterbox
Same here. Using the magic code don't seem to do anything.
Actually I didn't get to choose tpg as the sim card for calling. My option was greyed out.
carboy00
Managed to get VoLTE to work on Redmi Note 3. Try the following steps.
1. Go to Settings > About Phone
2. Scroll to Internal Storage and tap it quickly for 5 times.
3. Testing screen will appear, select phone information1 if your TPG SIM in in slot 1, phone information2 if in slot 2
4. Scroll down and you will see Set preferred network type and choose LTE Only
5. Remember to set Region to Malaysia or India to get the VoLTE option to appear under SIM Cards & Mobile Networks.
Works on my Redmi Note 3 SE. Requires constant repeating of above steps as VoLTE will stop after a few days again.
Sent from Xiaomi Mi 5 using GAGT
Shutterbox
Anyone has this problem where the the option to set sim card for dial is greyed out?
Tried on Malaysia/India region & LTE only setting. Volte still not working on my RMN3 Pro using this.
Anyone else can get Volte?
sellbuyboy
my phone today suddenly no signal.... both sim cards...
sim cards work in other phone...
what happen???
Wishdom
Anybody got weird Indian articles popping up on your phone?
Sent from Ilovennp using GAGT
sellbuyboy
Hi.. my note 3 suddenly no service signal for both sim cards slot. I tried many other working Sims already.
Anyone have a solution?
Wishdom
Anybody know where to get cheap replacement battery for redmi note 3? My battery takes forever to charge....
walamak88
Mind to share on how to get the data working? Already set the APN but mine shows no network. Thanks
jupiter12
Anyone Kenna reboot loop on xiaomi phone before??
Any idea to solve it or can flash rom again?
Now cannot get into Android OS at all.
