Xiaomi Redmi Note 3
weeza77
The problem with sending to service center is the data need to be reset even for battery change.
dolphinv
Hi recently my 1.5yr old redmi note 3 SE has been experiencing slow charging, so slow that i reformatted/tried various cables but no use. At first after reformatting it would still charge normally but next day same thing would occur. Does anyone have any ideas? I am thinking of bringing to service center. What are the possible charges?
seems like battery spoil.
carboy00
Possible it is an issue with the battery. My only concern now is if Xiaomi service centre still carries battery for older model. Tried asking for my Mi 5 and they said they don’t carry parts for it... they don’t have a service hotline to call and check so only way is to make a trip down to send in for repair to see what they say.
happyko
This was what happen to my Note 3SE
[/IMG]
[/IMG]
Ordered BM46 from Lazada SG. Delivered within 3 days. Damaged $25.
Pocoyoz
Dunno why cannot update to 9.5.7 from 7, update failed.
Sent from Pocoyo fan club using GAGT
FinalTidus
Just asking..
Are we getting MIUI 10 for our redmi note 3?
Wait long long liao still no news.
carboy00
Just asking..
Yes eventually since it is an old model hence very low priority. Even newer models haven't gotten stable Global MIUI 10 yet. You can give beta Global MIUI 10 for Redmi Note 3 a try if you wish.
carboy00
Why is there no firmware upgrade for note 3? Mine is still in Android 6.
Something until now Mi hasn't given a proper explanation (and never will). Definitely not hardware issue because Mi Max 1 has same hardware and gotten Android 7 update. Redmi Note 3 will get MIUI 10 but just not on a newer Android version.
JuXn5566
Redmi phone usually will get one android version upgrade or for some model no upgrade at all. Mi series phone might get more updates but for most is also one time only. Redmi Note 3 started with 5.1 and now is 6.0 so it's consider done. What Xiaomi will continue to update is security patches and MIUI version
which will bring in new feature.
Sent from ZTE A2017G using GAGT
molecule
Definitely more frequent updates than major brands like Samsung and LG, especially for low end fones.
