Xiaomi Redmi Note 4G
caterham7
Does anyone using the redmi note as music player? I find it quite good paired with audio technica IM02.
However, the constant stuttering pause and static pop makes it unbearable. Is anyone facing the same issue? Mine is note 4G.
Tried using Google's Play Music app instead of the default Xiaomi music app.
Less stuttering
frekedech
Less stuttering
Yup... I'm using google music since i discovered it couple days ago in the google apps folder :s22:
Anyway, I have updated to v22 and the XM music is much better now, apparently they have disabled the animation that might cause the stuttering.
BUT... Another thing that make the music stutters is network switching 4g to 3g vice versa. Thats freaking annoying when i'm on the train or bus. Regardless of whatever music player i used, its been like this since i got it on v21.
Dark Sumo
So far listening to music using Poweramp no problem but have yet to try while travelling in MRT (as its a new phone)
Sent from GAGT Android App
tnk001
Anyone managed to get Google Now launcher to work? I can't seem to make it work despite following the instructions on the net.
caterham7
Tested, working.
Need to select the launcher
Go to Settings -> Apps -> Default app settings -> launcher
Then select the Google Now launcher to be the default
p.s. am using nova launcher
jordanlowlowlow
Hi guys, any bros here bought any xiaomi phone from singtel? do u guys know if they issued warranty cards or anything regarding warranty? i cant find my warranty. Tks! Sorry for asking it in this thread
caterham7
Purchased from Xiaomi, no warranty card. They can check whether the set is local set via serial number
ngbc
Looking to buy a redmi note 4G.
Anyone with one pls pm me
https://www.facebook.com/MiSingapor...5405486500557/826603167380786/?type=1&theater
Dark Sumo
got mine from Singtel also
no warranty card
tnk001
Tested, working.
Ok. Solved my own problem.
The most important thing is not to open the google now launcher after downloading. Then it will work =)
MohdNazz
WhatsApp
My Note 4G, having this issue.
The Whatsapp contact keep on disappearing from whatsapp contact. When i go to my phone contact list & try to add or send a whatsapp message, i could not do it. If Off the phone & On again, i can do it.
Anyone can advise.
Thanks
hehuafa
Okay, wll give poweramp a shot. :D
Poweramp is a paid apps. Look for hacked version on Google. Free full version.got. if you don't feel like paying. But if you are OK to pay. Buy in unlock key from play market. Very straight forward.
hehuafa
Unless you are a huge data subcriber and heavily used to watch streaming online videos at outdoor Is useful else 3g generally faster as its octacore as opposed to 4g which is quadcore based on antutu scores. N 3g model used one is much cheaper. Further 3g mode one have dual sim. 4g mod is only single sim.
