Xiaomi Redmi Note 4G
mokseng
Diff processor, mediatek was octacore 1.7ghz, snapdragon is quadcore 1.6ghz. Was dual-sim, now single. New note supports wireless ac. Microsd card slot supports up to 64gb instead of 32gb.
yiptw89
Diff processor, mediatek was octacore 1.7ghz, snapdragon is quadcore 1.6ghz. The battery was 3200mah, now 3100mah. Was dual-sim, now single. New note supports wireless ac. Microsd card slot supports up to 64gb instead of 32gb.
Battery is the same... It is always 3100 mAh.
Min 3100 mAh/Typical 3200 mAh
Alexz_Hong
also comes with Android 4.4.
mingfreakrsx
Note 4G is on Android 4.4.4 , Note 3G is on Android 4.2.2 . 4.4 update coming to Note 3G around end of 2014.
Sent from GAGT Android App
halocast
more ex, single sim. 8gb rom, slightly slower processor.
Good thing is on 4.4 kitkat, which probably will perform better in day to day imo.
wait for next gen mi note better :o
come on xiaomi.. still waiting for update for the 3G version.
Devilsire
Those that are using 3g dual sim version now, will you change?
3g
.dual sim
.mediatek octacore 1.7ghz
.wireless b/g/n
.support up to 32GB microsd
4g
.single sim
.snapdragon400 quad core 1.6ghz
.wireless b/g/n/ac dual band
.support up to 64GB microsd
The rest of the specs are the same
Reserve my opinions.
- Mediatek -> Snapdragon400 isnt exactly a upgrade, at least based on past redmi1 to redmi1s (runs hotter, higher battery consumption).
- 3g note is able to support 64gb microsd (just need formatting)
Being single sim already written off this model for my usage, so yeah, Redmi Note 2 next pls
allanzzz
dunno if they use both LTE bands 1800mhz and 2600mhz or just 1800 only
caterham7
I presume the camera is the same as Redmi Note? Tried both Redmi and Redmi Note previously. Preferred the photos from the Redmi. Redmi Note photos seemed more noisy
geckoSG
the phone is sluggish after a while. so nope for me. performance wise. I rather pay more for a better phone now
caterham7
you mean the 4G version with snapdragon become sluggish?
btw, did you try with nova launcher? i normally use that instead of xiaomi's default launcher. i think nova is a little lighter in terms of resource usage
