Xiaomi Redmi Note 4G
allanzzz
the 4G is useless for gaming
lol my dual sim 3g redmi note gets 32k antutu
the 4g redmi note only gets 21k, bottom of the list
during the 3d benchmarking, the 4G was running powerpoint slides at 4fps, the 3G was running 21fps
yonglimm
Hi guys, may i know what documents you need to produce when you rma the device?
Packing list need a not??
Not necessary, packing list makes it easier for them to check on your phone warranty with the order no....if not, then they can also check the serial no inside your phone....
renfred89
oh thanks for the info.. was about to panic when i realise i lost my packing list and receipt online..
Thanks, i also throw the packing list away already.
Strange that there's nothing inside except that piece of paper
Johnteoh
The 4G version also don't seem to have the access app which allow me to set which apps need to be unlocked before one can use. Can other confirm this point?
blackjazz84
Did anyone encounter security breach tobyr credit card after u changed to xiaomi? I got a breach after a day of usage.
blackjazz84
Alamak...wat exactly happened? I aso just started using the note.
I don't know whether they got my credit card data before or after I changed to xiaomi. Apparently it happened 12hrs later and a SMS was sent to me by the bank of a breach. I called them up and queried. They will block my card and send me a new card. A merchant named grand beach. Wtf??
twentytwoeighty
Any quick review from those who have collected this baby?
Bought one to play with versus my Note 3, so far
-Chrome is uber smooth
-UI is also smooth and easily more user friendly than Samsung
-720P screen is OK and color temp at Warm looks accurate enough. Not as good as Samsung but then again $230 vs $800.
-4G is OK
-Spare battery $11 Xiaomi vs $68 Samsung = lolwtf
-Cannot copy files direct to internal storage from PC, but can transfer to SD then copy it over with file manager
-MP3 will lag if you are also viewing 2000+ photos at the same time. Sound quality on Note 3 is a wee bit clearer with Pistons 2.
shlee2114
Hi bros, any updates about camera quality? I'm using redmi 1s now and would like to upgrade but heard the 3g redmi note's camera isn't as good as 1s. I think my 1s' camera is fantastic so if this 4g note is close in picture quality then I can consider.
caterham7
It's chui :(
autofocus not fast, photos look muddy, shutter speeds tend to be slow even though ISO isn't very high, and aperture is a respectable f2.2 [getting 1/25s on iso200]; default setting seems to give under-exposed photos
must warn you that i have extremely high expectations for handphone cameras
Johnteoh
It's chui :(
Err... Shutter speed will be slow if low ISO. However when I reviewed some pics, I realised the information of the ISO isn't correct. ISO 200 is shown as ISO 100 and 400 as 300.
