Xiaomi Redmi Note 4X
Sidler
I think high chance.
Can't decide if I should wait for 64GB though. Currently using a borrowed Redmi Note 3.
Alexz_Hong
Even on such a heavy skin, the battery life on the SD625 is pretty insane, especially with 4,100mAh. And this was me trying to run it harder, playing a lot more games and videos on it than i normally do. Normal use probably can get more screen on time. :s22:
Plastick
if QC is good, export sets are worth imo. unless you are dealing with something like LG G4 kind of QC... then better play safe haha.
cscs3
Saw on website. is 32G.
Redmi Note 4 (3GB+32GB, inGold and Dark Grey colour) available on 16th March at:
Good to know. If price is close, good to get local set. Hope Note 4 and 4x means the same phone. As base on Xiaomi miui site. Note 4 do have mtk and sd processor and there is also a note 4x.
Redmi Note 4
http://en.miui.com/download-309.html
Redmi Note 4x
http://en.miui.com/download-321.html
I believe local set is 4 and not 4x.
Audiology93
Redmi Note 4
Redmi Note 4x
Its Note 4x since the FB post says that it uses 625.
Audiology93
It's note 4 Snapdragon 625 version.
4x is for china and taiwan.
N4 mtk
N4 SD
N4X
Sent from Xiaomi REDMI NOTE 4X | Colourful Metal using GAGT
Redmi Note 4 SD and Redmi Note 4X both uses SD chip.
Most of the specs are the same. The minor differences are on the blue tooth and the network bands. The 4X specs are better in these areas.
Refer to the link below for more info.
http://en.miui.com/thread-524344-1-1.html
I see. Thought they are the same since both are using 625.
ZrE0_Cha0s
Good find!
4x is a better buy unless you only want local set
well actually nothing much BT 4.1/4.2 not much differences, since most bluetooth can have backward compatibility, with more bands is good for those always travel around the world (not like every month but yearly will travel out)
cscs3
Redmi Note 4 (not 4x) has 2 version. MTK x20 and SD625. I am not sure if 4 and 4x is actually same machine. Only know 4x has higher memory option.
This is a link comparing this 2 model.
http://m.gadgets.ndtv.com/xiaomi-redmi-note-4x-3994-vs-xiaomi-redmi-note-4-3713
garychengjw
