Xiaomi Redmi Note 4X
Audiology93
How do i know if the one I have is note 4x or just note 4? The box wrote 4x but the about phone says note 4
Sent from Samsung SM-G920I using GAGT
Means it is 4x. You can check the IR blaster location or see the antenna lines. Redmi Note 4 X20 has full metal frame but 4x has plastic for top and bottom for 625. Redmi Note 4x 4/64 is X20.
Sent from Xiaomi MI 6 using GAGT
nirV4N4
Mine is a Redmi Note 4X 4/64gb X20.. Position of remote control / IR Blaster is in the middle..
eWinter
idk if you guys know
theres this super good deal on Qoo10 for NOte 4X now
all 3 sizes ava
http://list.qoo10.sg/item/XIAOMI-XI...-32GB-64GB-DECACORE-DUAL-SIM-GLOBAL/534102364
Bought a few sets already.
$179 for 32GB, $205 for 64GB 4GB decacore eh??
Just ordered last night from this link... $235 for 4GB/6GB
Then buy other stuff, total $250 and use the $50 voucher.
Shiok shiok! ... $185 for this phone...
I like it even more when the free warranty is 6 months while most seller give 1 week ~ 1 month.
Hope the phone is good... Just bought it to play around :s12:
I am kinda techy idiot. Any things I will need to do when getting this phone from my seller? :D I saw previous posts discussing on installing Global Rom ? Thought seller already did it for us, whats the difference?
Audiology93
Some might be modified global rom, so have to check the firmware. I always re-flash the global rom to ensure that its clean but don't actually have to do that if its already on official global rom.
eWinter
Thanks! Any quick tips on how to check whether my global rom is a modified one? so if it is, I just follow the guide from previous forum mates to install the latest one?
hk7310
Hi expert, I need help!
I am using Redmi note 4x, encounter a problem with UOB mighty app. The problem is after login the app, it prompt me for password by a sms otp notification. This notification is too long to show all sms message on the screen. I need to go to the sms to read the password and back to this UOB app for an input. Once I back to this app, a new sms otp will activated and resend, so the earlier password become obsolete.
I call UOB, they can't help. Anyone can help?
windwaver
Damn, missed it. Any good deals for Note 4x now?
windwaver
Bro, lowest I found was $188 there. Where to find $179?
Hi guys, so far I'm sticking to Samsung Note because of the S-Pen, I'm not so concern about apps but I prefer a pen.
If I were to switch to Xiaomi phones, can I simply use any stylus? Will it work?
windwaver
I assume its from JBTC group. It was before they increased the price.
Thanks buddy. Is that the vendor that provide 6 months warranty instead of the standard 1 month?
aztech44
Yup they provide 6 months warranty.
For stylus.. Im not sure.
