Xiaomi Redmi Note 4X
Cannot believe I am going to say this... But the Hatsune Miku colour looks nice!! Maybe I will get one if I cannot find the Redmi Note 3.
fmradio
You mean by more LTE band is 38/39/41?
Anyway, I'm guessing someone will ask you to try charging with a QC charger if you're didn't :s13:
No N4X supports LTE band 3 and 7 to be used in Singapore N4 SD only supports Band 3. I am using a QC3 compliant charger I can see QC3 batteries being charged at 12V
ZrE0_Cha0s
yup i have to agree with u as its one of my favorite color as well, but this is only limited to rmn4x only other models i dun think there is.
deckcard
No. I bought the Note 4X and tested with a USB meter, I only see 2A, 5V charging, it does not go to 9V or 12V, hence I think QC is probably not supported. Btw, 4X in MIUI officially only have China ROM, but the Dev 7.2.9 or 7.2.16 for Note 4 Qualcomm seems to be able to flash on 4X. 4X supports more LTE bands then Note 4 SD, the N4X phone with a N4 SD global ROM connects to 4G fine, but I do not know if it can support both 1800 and 2600 Mhz for LTE. It also seems that the baseband filename is the same. Anyone knows how to verify?
Cool thanks bro, that clears my doubt becos I see online saying it supports quick charging we all know how the media is so until someone really done a real life test, we can't trust. I really hope it has qc similar to the MI Max especially with such a big battery but we can only wish
stylechap
If it have Quick Charge,i don't see why official xiaomi site don't advertise it.
Mi max doesn't have Quick Charge anyway.
deckcard
MI Max has qc( I don't know 2 or 3), it charges very quickly which is why I was curious abt 4x becos it's a newer phone and using Snapdragon also. The qc circuit does add to the cost but since they can make MI Max low cost and have qc, I don't see why they can't do it on 4x.
I still think MI Max is most bang for buck phone if can live with the big screen
rabbit1
What the difference between this and note 3? Other than the inferior CPU
deckcard
Amazing SOT... The 625 really efficient and low power consumption. Hehe
