Xiaomi Redmi Note 4X
Sausage
is this a good buy compared to the redmi 4a for this price point? I know the specs are better but for the price should i go for something more powerful?
amazingone
Redmi Note 4X is more better than Redmi 4A, go for the Note if you can
ablurcat
Redmi 4A although is dual sim but sim 2 only support 2G.So if use locally only one sim working.
Kiwi8
Deluxe Member
Are u sure Note 4X is at the same price point at 4A? Note 4X is definitely better than 4A.
I have both phones.
Kiwi8
Deluxe Member
is warranty necessary? how has it been for people been using this phone?
Is like buying insurance, u nvr know when you need it
So far I using less than 1 month only
Difference is only like $10-20 for 6 months warranty
I have a difference opinion on this.
Since it is shop warranty, I generally do not trust shop warranty especially if it's like some months down the road. They might just blame it on user problem.
So I wouldn't really pay extra for extended warranty, and just make use of the existing warranty (albeit short) to thoroughly test out the functions and exchange for a new set if anything goes wrong. Shops are more willing to exchange new set if it's just a few days to a week of discovering problems with the phone.
Of course, also note the price point too. Since it's really such a good price, I'm happy to take the phone with short warranty period without topup for extended warranty. :o
toffeelatte
okay thanks. so this is the best price right now? not familiar with the price range
Kiwi8
Deluxe Member
Seems more expensive leh.
I bought my 3GB/16GB model at $158, with Qoo10 gift card and Q-points reducing it to $150.
I think it was sold even cheaper before though.
toffeelatte
wah so cheap?! by the same seller? btw does it come with headphones?
toffeelatte
btw where do you all buy the case for this phone from? just want a simple and cheap one will do
