Xiaomi Redmi Note 4X
SkyShroud
err this one not tb one.. can sic the link you bought from tb mah? thanks much
that u muz ownself slowly find liao
tb casing is mostly catered to china xiaomi redmi 4x, so a lot of casings though look similar, does not have the extra holes for global
i bought it from aile, i lazy to browse through that thousands of pages to search for one casing made compatible for global. even if found one, difference is just 1 or 2 bucks
toffeelatte
ok thanks sky
need some help... i'm looking through tb for the case, just to confirm over there it is also under the name xm note 4X right? my chinese not very good so i'm just looking for the keywords.. scared buy wrong one
wadsad
Got this phone today. Everything very good. Only one thing no good. Not bright enough.
micey84
ok thanks sky
just look for those note4X标准版 if yours is 16/32gb
frozenoob
i thought so too. until i meddled with the brightness settings. otherwise its dim
edit: im not referring to the standard drag left-right bar. i went into the actual settings and tweaked something.
SkyShroud
thats nice. but how do i know the seller i'm buying from include the free tempered glass?
It will stat so, you first time buy online mehz.
Most cheap priced casing won't have free protector de lar
Then those include protector usually won't include any wet tissue, fiber cloth, sticky dust removal or solutions for "white" sides, unless is a "expensive" bundle
Aiya, just pick one you like and buy, is 3 to 5 times cheaper than sg anyway. Local easily $10 for protector, if branded easily $20.
vibranze
Doogee got leh :)
Sent from Xiaomi REDMI NOTE 4 using GAGT
toffeelatte
ya first time buying from them plus my chinese is hopeless. not getting due to free stuff but just wanna know how to know since some do give
noangel7
thanks to this thread, bought my phone! Lazada $167- $20 (citi)- $5 (liveup)=~ $142
For casing, what's the best place to buy? Shopee ok?
wadsad
disable auto brightness? i disable liao. still same. :(
wadsad
btw got 1 more "issue" need help, not sure is pertaining to android 7 or the phone UI.
my old phone on android 6 will show the message body in notification. now this one even if only 1 message, wont show header or body at all. just show sender.
current.
hoping to change to this.
thanks :D
Scooby-Doo
Hi guys, I am on a tight budget as my pay is relatively low, but I would like to buy a decent main phone for messaging, facebook and watching the occasional YT/Whatsapp videos. Is this Redmi Note 4x worth the money or better to spend another $100 for A1 near-stock android?
P.S: Anybody know where to find the Miku blue version from authorised retailers?
