Xiaomi Redmi Note 4X
Kiwi8
Deluxe Member
cscs3
Note 4 is local warranty 1 year.
Note 4X is export set, with 1 month warranty from shop.
Both Note 4 and 4x had export version. Different is warranty version (Xiaomi agent set) bassically a Note 4x version but named and Note 4.
To Miui, both are displayed as Note 4. 4 and 4x has some physically diffetent in real. But not for Note 4 warrant set vs Note 4x.
windwaver
1st one is 1 year local warranty
2nd one is export shop 1 month warranty
Top IR blaster also different for 4x and 4, bottom speaker as well but that's important only for casings, if not, hardware is exactly the same.
Whisper
The new miui 9 doesn't tell u the hp is fully charged right? It used to tell me to unplug charger when fully charged.
We_Generation
Hi guys I am interested to buy this phone, any recommendation where can I buy at a good price and how much is consider cheap or worth it for 32gb? Thanks!
Krabs.
The price hike now is like "not worth it" compared to 1-2 months ago
Kiwi8
Deluxe Member
Anyone using Telegram? Any recent issue with no alert sounds?
Not sure is it due to a new version of the app or the phone issue. :s22:
Whisper
How to keep screen on when using the default video player to watch MP4? It keeps going to sleep.. :(
micey84
can change settings under lock screen + password, choose the amount of time of inactivity for the phone to go to sleep
Ultimo_Urien
Dk why but find it hard to let go of my xiaomi note 4 for other similar mid range brands after using it for few months.
Whisper
Found it..tks but shouldn't the screen be auto on when watching videos?
windwaver
Not surprising bro.
Where can you find a phone with this spec at this price range? Some 2nd hand or refurbished phones already cost around the price of a new 4x (export version).
windwaver
Yeah, I just checked, it's $169 before any discount. Lowest I bought was $149 before discount and $131.12 after 12% off.
For those wanting to buy the 4x (3GB/32GB), wait for 12.12 to see if it drops to $149 or lower.
Ultimo_Urien
Not surprising bro.
It's the battery life+smooth performance that makes note 4 shine, furthermore miui ish really a blast to use.
Used to lub sony xperia but they let me down on battery dept apart from their compact series, samsung just too overpriced.:(
Overall xm note 4 still the best.
windwaver
Agree.
The recent custom ROMs and also MIUI really allow the Note 4x to shine. It's a good trade off between battery and computing power.
The 4000mAh battery can last for ages and it's even more powerful than the newer A1 with 3080mAh.
Dimensions and weight is also excellent.
The only fault is probably the inferior camera compared to the A1 but a camera doesn't really matter to me (the price does).
For those who doesn't mind camera quality, the Note 4x (Snapdragon) is still a very good phone.
