Xiaomi Redmi Note 5
Nakedtoes
Yep unlocked. But no matter which rom I flash to, it will still be 9.5.6.0 OIIMIFA after the reboot. Tried both Global and CN ROM.
Sent from HUAWEI MATE 10 using GAGT
i read need to flash lower version rom then can ... or u try developer rom first..
Just Me
JTBC 32 gb $195 64gb 239 again... those interested go go go..
JTBC i bought redmi 5 plus from them is unlocked with modified rom then i flash using miflash to offical rom..
Bought from M- union redmi note 5 AI is china telco set sealed china official rom
Bought from New star redmi note 5 also china official rom
Bought from GLobal tech is global rom but malaysia set and under warranty from xiaomi singapore.
Just a guide..
Which seller carries the global model (red box)
Geo
JTBC 32 gb $195 64gb 239 - Redmi Note 5 AI Dual Camera (red box) but whether global rom depends on your luck. I got one with fake/modified ROM and I had to return it.
GLobal tech is global rom but malaysia set and under warranty from xiaomi singapore. This is Redmi Note 5 AI Dual Camera but not sure if the box is red.
Audiology93
amazingone
Malaysia sets comes in red boxes too.
chainer9999
Quite happy with my China rom so far. No difference except ownself install play store and some junk cannot Uninstall
Nakedtoes
JTBC sold global rom one also.. got bro here bought and got global rom... likely is 32gb version... AS mentioned i got fake rom redmi 5 plus also but did manage to flash to official global rom;).. For redmi note 5 case best is get global rom
chaiscool
Anyway to request for global rom or non fake rom when buying?
mar5000
Just got a export set from Mustafa at $269 for 4/64, but too bad they only have blue and gold no black, in the end go for the blue. Official global rom.
silverstar
I have tried the developer rom, the china miui10 developer and guess what? the about phone still says 9.5.6 oiimifa. I did attach some screenshots few pages back. seriously nothing works.
I tried to swap/return and the seller is saying there is no new version thats why still 9.5.6.......
Geo
Where did you buy yours from? Lazada, Shopee or some shop?
Bought mine from Lazada and managed to return it because of this OIIMIFA issue.
silverstar
As i mentioned before. My prev redmi 5 plus kena fake rom from jtbc, will notbuy from them again
darn, i wish i had seen this.
from jtbc @ shopee. This is actually my 1st purchase at shopee so I thot order received=receipt so I clicked receipt when I got it. So used to aliexpress. Now going thro shopee hoping to get a swap at least.
ngbc
Did you try TWRP Full Wipe (System. Data, Cache, Internal Storage) then flash official recovery rom or EU rom store on the SD card ?
* Of course remember to backup data first.
Seipher
Hi just wondering if anyone facing same issue as me.
I'm on global rom 9.5.13 and my YouTube app doesn't work anymore. When opening the app it just shows the loading circle and nothing else.
Tried clearing cache and installing both older and newer versions all don't work.
Mobile YouTube works fine through browser so it seems it's an app problem.
