Xiaomi Redmi Note 5
whoooo
I'm on oeimifa 9.5.13.0 stable global 9.5. How you get. 17?
17 being slowly push to user, just got mine
hyper_megaman
Singapore still no face unlock..
Face unlock is annoying. Sometimes u lock the phone, the lock screen immediately shows, and then will face unlock. Have to lock again.
It doesn't really save much effort also. How hard is it to tap your fingerprint at the sensor? Not hard at all ma. You have to press something physical anyway, i.e. the lock button to activate the screen before I can face unlock too, so it's not like face unlock is hands free.
I turned mine off haha.
bbcccc
same sentiment too . . .
Sent from LG G6 using GAGT
hyper_megaman
on a few occasions, i'm trying to lock and everytime i press the lock button the phone locks then immediately lock screen comes up, then face unlcok again. in the end have to lock the phone with it facing somewhere else then trying to peep at the screen from the side.
might have to do with my casing.
after a while i feel no diff from fingerprinting. might as well disable it. more trouble than help.
if it allows me to activate face unlock without hands, e.g. by voice command before it scans my face, then that would be great. but alas u still have to press the lock button to wake the phone, might as well just tap the fingerprint sensor.
Nakedtoes
Can install a lock screen button.. So easy.. Faceunlock is good dun need to lift phone to press the fingerprint sensor.
xFidelity
Juz received my note 5 pro frm jtbc and it is the global version.
Can ask if yours is a 4/64gb version?
I've always wondering if jtbc sets are random or is it always the 6/64gb sets that are with the fake/custom rom OIIMIFA
