Yep. No future updates. Have to flash to an official rom, which none of us have an idea on how to do it yet. Maybe can try the test point method but I'm not doing that and risk my return
Sent from HUAWEI MATE 10 using GAGT
Think logic is just buy a local warranty set to avoid trouble of unlocking or flashing left and right.
Redwhite M still selling at under $300 right?
Not for now. Even the red Mi A1 didn't come to SGRed local sets not available here?
It's such a shame.
Seemed like even test point also can't resolve the OIIMIFA fake rom issue :
http://en.miui.com/thread-2990827-1-1.html
so, make sure don't get from JBTC/BooM unless you can find way to return it OR they promised to send you factory-sealed with CHINA or GLOBAL rom !!!
When loading cam app or when taking photo or after taking photo( processing time)?my rm note 5(JTBC) occasionally faces some lag at the camera app. It will hang at the a still image and I need to wait for a few second. Anyone experienced the same issue?
Just bought 4/64gb from premier mobile at lazada for 240. Hopefully the rom not fake. I did read the Q&A before purchasing it seems to be sealed with global rom installed.
Posted from PCWX using ONEPLUS A6003
Redmi note 5 pro ?
do u set camera to save to sd?my rm note 5(JTBC) occasionally faces some lag at the camera app. It will hang at the a still image and I need to wait for a few second. Anyone experienced the same issue?
Hi, anyone knows where to purchase Note 5 flip case?
Dear MIUIers,
To maintain system stability and ensure the security of the device, we have introduced a mechanism of anti-rollback. After you have updated to MIUI 10 Global Public ROM 8.7.5, please don't try to downgrade your ROM to previous Stable ROM and Beta ROM. Otherwise, your device will be bricked, which may also affect your device stability. If your device has been bricked, please go to the nearest Mi service centre for help.
Does this only apply to rn5 series?
why would they implement anti roll back
