Xiaomi Redmi Note 5
Nakedtoes
Global rom doesn't mean is local set.. Just for info.. So far if u enter imei number it show country of delivery Singapore or Malaysia then is local set.
Nakedtoes
I using global rom.. Mine mum using China rom.. Mine set no VoLTE and Bluetooth no support aptx.. Once check mine mum set will see is because of rom.. Cause mi max 3 China rom got the 2 functions
gnixer
for sure is not local set bcos this colour is only available in china.
just want to use global rom instead of china rom.
wongminmin
anyone can recommend some good or decent case for this phone?
https://detail.tmall.com/item.htm?i...e8dE7Y8H9&_u=h25bhghk48f2&skuId=3645569044643
testerjp
Ordered from this Techbox company.
Claim to be able to deliver in 3 to 5 working days.
Now 6th day liao still no news.
PeasantBeing
The free silicon case not good enough...?
Sent from Xiaomi REDMI NOTE 3 using GAGT
To me the free case is OK but I don't think it can protect the phone if drop from height or fall onto rough ground. So I want to get a tougher case.
2xEng2xCheng
Hi Nakedtoes, I would like to check with you, any cons for China ROM. If not, maybe I don't flash my phone to a global ROM.
ZrE0_Cha0s
How much u paid for this red 4/64gb with global Rom? This one runs sd 636? Can share link?
Lol if Redmi note 5 not SD 636 den u are looking at wrg phone lei :p
Jks (it's India fault for making redmi 5 plus as the note 5 and note 5 pro is like China note 5)
Nakedtoes
no cons..:D:D:D infact i dun see a need to unlock bootloader and dun see a need to flash global rom.. for mine phone , family members one and relatives and friends one... they all nv encounter any problem..
ok i just check on the latest global rom vs china rom... m1 sim card... china rom support voLTE... global rom no... china rom got steps counters etc.. global dun have... and there are others also... china rom usually more stable , got the fastest updates and the most features.
Hailgod
there is a con. every miui update will bring random china apps that u have to uninstall. and recently the vibration on every sync bug was introduced and fixed around 2 weeks afterwards. these random weird ass bugs are usually not present in global rom.
