Xiaomi Redmi Note 5
PeasantBeing
Ya I reset the APNs to default and added back my republic and TPG apn.
Sent from REDMI NOTE 5 on Rocket Uno with TPG Booster using GAGT
rootz
Anyone facing problems with adding Google account? It keeps stating server issue.
fireantz
Not sure if it's related to the upgrade, my phone decided to stop vibrate even with the vibration setting turned on. Anyone encounter this issue?
limjialok
Anyone knows where to buy those thick transparent bumper ? Shopee and Qoo10 sells $2-$5 is all thin bumper without much lip at the front to protect the screen
PeasantBeing
Anyone having problem installing Netflix app? Mine say device is not compatible...
Because your set is not local set?
Mine ok, mine is Malaysian set supposedly with warranty by local service centre.
guanhwee
I had 3 sets at home, all china set....but one is okay and the other 2 is not. Phone works fine...all system updates are up to date...just that 2 of the phones cannot install netflix
8-lane
I might wanna get this phone for my mum... which colour of the phone do u guys think is nicer ar... black, gold or blue?
8-lane
Suntec Mi Store selling Redmi Note 6 Pro 3/32 at $158 as well but I think only got one colour.
https://www.facebook.com/MistoreSuntec/
Oh wat is the colour left at Suntec? The sets at both Nex and Causeway Point outlets have all sold out is it? The prices for both configs are v gd... do these Mi Stores only sell phone sets with official 1 yr Xiaomi sg warranty?
carboy00
No mention of what colours left, you may need to check with the stores. Suntec, Causeway Point and Nex all should have since they are under same distributor. They are official Xiaomi stores hence 1 year local warranty included if buy from them
Posted from PCWX using POCOPHONE F1 Rosso Red
8-lane
Ic thanks...
3/32GB is good enough if you don't game but a 4/64GB configuration will be more useful in the long term or if you play some simple games.
Ic den it'd be suitable for my mum.. thanks..
This may come in handy.. thanks..
