Xiaomi Redmi Note 5
ZrE0_Cha0s
When u all say redmi note 5, is the pro or plus version?
pro is india set,
plus is the redmi 5 plus (the so called basic redmi note 5 in india.)
china set have no other naming beside saying it rams+storage differences.
ktyandkyc
pro is india set,
Oic if u hoot 4/64, it's probably equivalent to India pro?
TitanSmall
4+64 @ $277 (after all discount) worth buying? Gold colour. Free miband 2
Nakedtoes
https://m.qoo10.sg/gmkt.inc/Mobile/Goods/goods.aspx?goodscode=609154844
Ya qoo10. Use $50 coupon. Then buy 3 gift card.
If you got shopback got further cashback
Thx.. Actually now the best is 32gb/3gb ram since can expand storage.. 32gb/3gb now abt 212 after all coupons and gift card discount. But no miband.. Miband the most u sell for 10 only
Seller w digital
TitanSmall
Seller w digital
You think 3/32gb good enough ah?
Nakedtoes
I feel 3gb and 4gb not much different until u get 6gb ram.. Cause I compared both before.. Cause sd636 is quite fast even can't store more apps in memory they load apps pretty fast..
Nakedtoes
3gb $212 4gb 277.. The different is 65.. So to me unless different below 50 or ard 40 then 64gb/4gb worth..that time I bought 64/4 at 279 and 32gb was at 239 so 40 different only..
Nakedtoes
but someone said is china rom, no playstore
They will install for u.. Actually very easy to install yrself too.. China rom maybe have problem with Google pay etc but since phone no nfc so not an issue.. Dun care China or global rom.. Not much different one.. Infact China rom got more faster and latest updates then global..
amazingone
Planning to buy either redmi note 5 pro or mi note 3 . Which one is the better buy ?
If you prefer the long 18:9 display that's in the trend now, get the Redmi Note 5.
If you prefer the traditional 16:9 display, get the Mi Note 3.
