amazingone
- Jan 14, 2015
H+ is another representation of higher speed 3G.I realised mine also have. Even H+ also have... why ah?
Guys anyone know what is 4G+ ? Just Notice the + on SingTel signal bar
Notice you own the latest MIUI. Can ask if you battery problem ? Thanks.
Can refer to the Malaysia's Redmi Note 5, specs are the same as Singapore set.Am considering this phone. Been so long. Lost track of the discussion.
Is SG this the China/India version ? Is the official specs for SG phone available ? If not, which one should I refer to ?
Thanks very much...
What apps don't work properly.. I using China rom and global rom.. Both no problems with any apps.. Dun anyhow bull..Some apps dont work properly. best is to flash gpobal
http://www.mi.com/my/redmi-note-5/
Hi-tec from Lazada is selling global ROM redmi note 5 at 280 for 64/4gb , anyknkws whether it's legit
Camera specs seems to suggest it is Redmi Note 5 AI but the spec also says the Android is version 7. Acc. to gsmarena, Redmi Note 5 AI si on Android 8.
I asked them on Lazada is this Redmi Note 5 AI and they said yes.
I am confused so I am holding back my purchase.
this is the chinese version where the seller opens the box and flashes the official global rom. good deal for 280.Camera specs seems to suggest it is Redmi Note 5 AI but the spec also says the Android is version 7. Acc. to gsmarena, Redmi Note 5 AI si on Android 8.
Good price.![]()
1st - 3rd June 2018 Suntec
Source: https://www.facebook.com/XiaomiSing...405486500557/1990812380959853/?type=3&theater
Wah $349.....I bought mine $300 and only 4/64![]()
they said it themselves in the QnA.
Bro, I went to http://en.miui.com/ but I couldn't find any global ROM for the Chinese variant of Redmi Note 5 AI so I am not sure if this is really the Chinese variant.
Do you have the link to the official global rom?
I bought my 6/64gb for 329. 349 with local warranty is good deal. Free mi band some more.
Sent from Xiaomi REDMI NOTE 5 using GAGT
