Xiaomi Redmi Note 5
Hailgod
How to turn off MIUI Optimisation?
go miui 9.5 and tap miui until you get developer settings.
then go settings > additional settings > developer options and turn off miui optimization and memory optimization
Sent from Xiaomi REDMI NOTE 5 using GAGT
ktyandkyc
The note 5 pro battery life is insane. Used for 9 hours for work (job app + Google maps) with gps and ended the day with 14%. If I were to use my 3yo iPhone 6s I would have charged it 3 times in between
U using stock miui os?
zirdaj
Is it very troublesome to flash global rom? I saw a guide online from xda and seems a lot of work, not sure if there are any other better guides around. The redmi 5 plus I got does not have play store, sigh. I will just return this if I can risk bricking the phone by flashing myself.
Also, on youtube there is a guide to install playstore from Mi Store, what difference does it make from flashing a global rom?
Hailgod
not much, global rom has better notifications but china rom gets faster updates. im staying on china rom myself, installing google services is very easy.
https://www.reddit.com/r/Xiaomi/wiki/roms/optimise
zirdaj
Ah I see. I never fully understood the Global ROM thing, I thought the phone would be unusable outside China if you do not have Global ROM flashed, seems like it is not the case.
lls8450
Me too. I'm also on china rom with google services installed.
Hailgod
I'm using the one that came straight out of the box. Btw what is miui optimization?
heard its for chinese services and can actually make google apps run poorer. turning it off improved both my standard SOT and standby battery drain. now is around 2% a night instead of 4%.
yusoffb01
Some apps dont work properly. best is to flash gpobal
csc12345678
Am considering this phone. Been so long. Lost track of the discussion.
Is SG this the China/India version ? Is the official specs for SG phone available ? If not, which one should I refer to ?
Thanks very much...
ZrE0_Cha0s
Thanks very much...
Export set both version. Local set is China international ROM.
whoooo
Guys anyone know what is 4G+ ? Just Notice the + on SingTel signal bar
