Xiaomi redmi note
hyper_megaman
Hi to all,
I got a parallel import set. Anyway to reinstall the OS and convert to a local set? How do I go about doing it?
The local store at Sim Lim charges $30 for this service.
Thanks.
why the hell would you buy from sim lim?
it's highly likely it's a fake
anyway what's your issue here? you mean can't access local 3g netowrk?
tjkb230
i notice my note took more then 2 hrs to charge from 20%-90+%..
This is normal. After 90% is very very slow, slower than first 10% and much much slower when phone is at 50%.
I took ard 3.5hrs to charge frm zero to full. Normal bo?
Take 3100 mAh divided by the current input to get a rough gauge: 3100 mAh / 1000 mA = 3.1 hours
But we know the charging-time relationship is not linear, so if you expect it to be 2 hours that's quite impossible.
Frederick84
tats what i tink also.. okok.. thx for confirming..
really should have made the note able to accept 2A
they say cant use more then 1A de charger on note ??
my wife de is 1.8A wor.. can use on note ??
juuzbe
having 2 Note on hand. how come 1 is able to update to JHDMICE29.0 but the other one no matter how u check keep tell you is the updated one but is only JHDMICE23.0
Anyone can enlighten me?
hyper_megaman
i'm not sure, it happened to me too. i had to manually update by downloading from the miui website
yhw22
Both bought from Xiaomi Online?:o
hlw8888
i am still able to add redmi note battery and batt charger in cart sia. :o
tjkb230
G2 charger? Can... just that it will only take in 1A from that charger that's all.
Devilsire
Redmi note is able to accept 2A, try it yrself & use battery monitor app. Infact in China, Xiaomi note & pad are all bundled with 2A charger.
Singapore & international market are being shortchanged as xiaomi did not / have yet to start production of 2A UK plug chargers to cater for us. They simply threw in the lowerend 1A model used for redmi1/1S.
