Xiaomi redmi note
denilson
Yup setting done for data connection as well as data roaming enabled. Went to Tmobile shop n the guy said that it's not phone problem but Tmobile network that restricts mui os cos they do not sell such phones here. He also said that another customer with oppo phone also hv same problems... Haha guess got to wait for xiao mi to flood Europe markets.
check apn settings?
halocast
Hi all, anyone having problems with xiao mi note in other countries?. Presently in Germany now n bot a Tmobile prepaid data card. Can't get on to the internet at all. The message says that internet browser is restricted from using data networks. Anyone having this problem? Any setting to get around this problem? Thanks in advance.
Andy
go to yr security, data usage , restrictions..
see if yr browsers can restrict anything bo :s12:
btw 37 stable update is out. :s12:
- improved the security of cloud messaging.
dunno got what else changed
hyper_megaman
no that's not it i think
i don't see t-mobile in germany's list of UMTS networks
http://en.wikipedia.org/wiki/List_of_UMTS_networks
If germany is not using the UMTS/WCDMA standard, your phone doesn't support
Most sg phones wouldn't work i think
you have to get these networks' services
E-Plus Germany
O2 Germany
Telekom Germany
Vodafone Germany
denilson
List of UMTS networks - Wikipedia, the free encyclopedia
E-Plus Germany
O2 Germany
Telekom Germany
Vodafone Germany
I think tmobile is under Telekom which uses the 2100 band which the redmi supports
check the apn settings
lazy999
Anyone encounter their wifi switch off by itself? I already set keep wifi on during sleep but sometime its will off by itself.
hyper_megaman
i think you're right, i apologise
in that case there should be no problems if all data and apn settings are in order
ahder_76
Hi all, anyone encounter problem when typing yahoo email? From start, when i replying email i don't see my anything in the reply box. All letters are in white,same as the screen colour.
ekardo
not sure if it's a xiaomi prob..but how to dismiss the birthday notification from calendar from lock screen? I press back, no effect, pressing the centre square button seems to be snooze cos the notification came back again after a while..
what to press to dismiss it and dun notify again?
GY_Ren
My Redmi note recently occurs a problem whereby the wifi is not able to detect or even it is detected and connected, there is no data flow... Other devices working fine with my wifi...
tinsel77
rear camera quality
hi,
planning to buy a Mi Note. May I know how is the rear camera quality? Heard that the 13 MP isn't really so.
Thanks
Cissiboy
hi,
Thanks
having said mpx dont really give you an indication on quality, the camera imho is very very good
Alexz_Hong
hi,
Thanks
It's not great, but it's not that bad also. Some shots here.
https://www.flickr.com/photos/axhng/sets/72157645358205087/
