Xiaomi redmi note
kweeli
If you have one, close look at top left lcd panel. I found three sets have the lcd panel peel off issues. Slightly press on lcd panel, you ll see the panel is moving. After press it stay but peel off again after awhile.
U also can see some dust at front camera lends. Sent one set for warranty but less then two weeks same problem happened again.
stillgottheblues
The price of the phone is so reasonable that you can just replace another set without feeling heart pain.
yonglimm
According to my father who was using my phone then, they managed to spot some corrosion on the motherboard and claimed that it may be due to 'exposure to water' which may void warranty.
Sent from GAGT Android App
post on xiaomi facebook and see what is their response...;)
walkofwinners
I've got a set of note 3g with receipt to let go if anyone is keen. Pm me and pls don't offer me ridiculous prices. Thanks
sonic
Got some problems with my 3G Redmi Note.
Just went oversea stay hotel with free wifi. The 3G note after connected
to the free wifi, a hotel login page supposed to pop up automatically but it
don't. So I cannot use the hotel free wifi. Same problem when at Changi
Airport transit area when want to use the free wifi. The page to key in mobile
number to get the pass code also don't pop up.
No problem with my iPad at the hotel & Airport. Once connected the page
will pop up for the needed login.
Anybody can advise?
mingfreakrsx
Anybody can advise?
Try going to your browser and load a webpage eg. Google. The WiFi login page may appear. :)
sonic
Tried, cannot. It said page cannot load..
I tied my iPad & wife Mi3, once connected, the login page will auto pop up..
None for my 3G note..
ekardo
i think more of user problem...
you have to try google.com and not other address...
ekardo
oh..that's after confirming that it's connect to wifi and doing other network check..
anyway, if deem faulty still under warranty....
sorry...not trying to protect xiaomi or aiming at you...
Yuripa
Hi everyone,
I'm currently using a samsung galaxy s3 non-lte for almost 3 years and I guess I'm pretty much looking for a new phone to last me for the next 2-3 years down the road.
My 1st choice was LG G3 beat ($249) but due to budget constrain I decided to go for Asus padfone mini ($199) BUT I'm now gonna settle for a Redmi because the padfone mini doesn't have camera flash hardware.
I need some advice - should I be looking to get either -
1. Redmi 1S ($89) or;
2. Note 3g ($119)..?
Assuming screen size and price diff of $30 is not much of an issue to me..?
My main concern is -
1. Battery life/performance (well, worst case scenario just carry extra battery which imho doesn't inconvenient me in anyway at all)
2. GPS stability (1S is snapdragon processor while the Note 3g isn't, though I'm clueless if chip processor affects GPS overall performance or not)
3. Dual-Sim functions (both got)
4. Does the difference in ram (1S - 1GB; Note 3g - 2GB) make a noticeable difference in daily usage operation?
Lastly, many thanks in advance as I would really appreciate if I can get some advice from redmi users here :)
ekardo
both are consider on par with your current phone..you will not get any clear satisfaction from the 2 phone...except for the feeling of a new phone (like a new OS) and keeping you busy installing all the apps you want again..
my advice is, aim for higher spec phone...unless your S3 is really koyak already..
miffy.x
i hv chnage my phone from samsung to redmi..
Will the contact auto generate to redmi or i need to update one at a time ?
Thank You !
caterham7
Thank You !
If your existing contacts are synced to Google, they should automatically appear on the Redmi when you sign in to your Google account
Yuripa
I'm having a love/hate relationship with my s3. It's buggy enough at times to drive me nuts. And sad to say, there isn't any highend model out in the market right now that is really enticing at the moment.
Is it a want or more of a need for me? I'll say 50/50. I guess I want to get a phone now more for stability, durability and good battery life and at $89/$119 for either 1S/Note 3g I think I can afford to pamper myself a little :D
then go for note.
It's a better device device than any redmi 1/1S
So is the difference in chip is negligible?
yonglimm
bro... u can get $89 for Red 1s and $119 for Note 3G :eek:
can share ur lobang here? :D
