Xiaomi redmi note
halocast
I'm having this issue whereby whatsapp msg sometimes do not get pushed automatically. I have set to 'always pop up', but sometimes it doesn't work. I have to go into the app them the msg will appear.
I have locked whatsapp to prevent it from deleting it from background, have also 'trusted' the app in security.
Anyone else having this problem on their note?
don't seem so le..
:s12:
will test out more
botak33
I tried for you using my redmi note. My no-brand usb couldn't detect it at all. Then I use the usb provided by xiaomi to try. At first it read it as a camera and can't detect. But after plugging in and out the usb a few times, it appears as a "HM NOTE 1W" and I can then access the phone storage + SD card data.
Hope this helps.
Hi yan.an,
Thanks for the advise. Problem solved. There are actually 2 problems for my case.
1) You are right, I've used a usb cable with charging lines (supply & ground) only. Cable provided by Xiaomi comes with data lines as well instead.
2) I've plugged my usb cable on the FSB & thus insufficient supply. Changed to usb port on the back.
Hope these will help others too.
gongchen
Hi all, have anyone try to move/install app on SD card instead of internal storage for XiaoMi Note?
chenaz
anyone didnt get it? ordered it for free delivery for my powerbank.
anyone wants it?
innosia
purchased one redmi note for gift... second try and successful, first try is two weeks ago where can't login
Soomp!
gotten it also!
50 seconds sold out..
phew..
Tried going for note .. then tried 1s.. but cannot load the page.
When it is responding, it is telling me that it had been sold..
timpeh82
gotten it also!
phew..
Finally got my note. Using Redmi 1S for a week. Only issue is battery. So xiaomi is ok phone for me.
djzilch
Missed out on redmi note, bought redmi 1s instead Coz I was upset, lucky still have
Also missed out on the power bank *sad*
