Xperia Arco S
rachdanon
Acro S Case
Bros, need help getting Acros S case in Singapore. Anyone got extra or lobang to help me with it? :s22::s11:
sirbrian
I usually buy from:
Qoo10 Search - sony lt26w xperia acro s
I don't recommend the Nillkin as it cracks easily.
Alternatively you can buy from:
Amazon JP Search - Xperia acro HD
I bought my Case-Mate form:
Case-Mate docomo Xperia acro HD SO-03D / au XPERIA acro HD IS12S Hybrid Tough Case, Black/Black エクスペリア アクロHD 専用 ハイブリッド タフ ケース, ブラック / ブラック CM021133
sirbrian
6.1.A.2.55 Difference(s)?
By the way, has anyone update the system to 6.1.A.2.55?
Care to share what are the difference(s)?
waterballoon
anyone knows if Sony or anywhere else got sell the SIM card tray? i screwed up man... scratched my tray damn badly cos my microSIM adapter couldn't be read by the phone... now whenever i insert the sim card with the adapter the phone doesn't read it .__. and everywhere is closed cos of CNY.
anyknow uses microSIM for their acro s? how you all put in one, my acro s doesn't read the sim card at all!
sirbrian
Sony Xperia acro S LT26W Full Housing Cover -White - Parts4repair.Com
waterballoon
thanks! but no i'm suspecting the simcard reading pins are spoiled or something, cos whatever sim (micro or regular) i insert, the phone doesn't read it at all... wonder if Sony would repair this
foosoomin
waterballoon,
Try calling up the following service centre & ask
Isetan Orchard @ 6735 6193
Junction 8 @ 6358 1887
Hope my info helps
waterballoon
thanks I called the j8 one but apparently closed today also... sigh means need to wait until Sunday then I'm free wor sian. wonder what's wrong with my SIMcard reader... can't read the sim card at all!
quixote2nd
Dropped Phone
Just to recap on an earlier posting on dropping the phone.
I dropped mine about 1m high onto my house floor and the top right hand corner of the back cover was slightly opened & couldn't be closed properly.
Sony service centre charged me $400 to repair it saying that the LCD screen had to be replaced together with the back cover as 'it is connected'.
Also, they said that water has gone in via the microSD card slot based on the tiny white strip (located below the slot) turing red. I could have sworn that I seldom if never open the microSD slot.
Did anyone encounter the above?
Sigh... guess it's better to save up for the Xperia Z rather than repairing it.
hoouyoul
Jelly Bean Update
Hi guys,
Just to inform all of you that Android Jelly Bean 4.1.2 for Xperia Acro S is out. Upgrade it from Sony PC companion or Sony Update Service. :D
yhw22
Updated. Press and hold middle home button will bring up small apps and previous run apps.
