Xperia Arco S
chaud@sg
Hi guys, I intend to change to a new phone early next month which is november. My shortlist are Xperia Acro S, Xperia ion and Optimus 4X. Any suggestion? Does the headphone flap on the Acro S easily spoilt or inconvenient in everyday use?
pker88
advice those wnna get a sony
wait for new sony liao
arco s belong o the older version liao
kentgh
Just wait for the Xperia T/TX or V. They uses the latest generation of processors. They will be released by the end of the year. :)
chaud@sg
But the price is a point of consideration also leh, how much do you guys think the Xperia T/TX or V will cost once it hit the local markets?
rssd21
Its fair to say 700+ at release, but do not rely on the prices of the official retailers. Usually official retailers sell at higher prices compared to certain phone shops.
If you are looking at acro s, you can check out V for its water-resist qualities, LTE, bravia 2, clear audio+ and docking without need to remove any caps.
sharkapl
tried, it doesn't work leh. tix is what i google but don't work. Or must I root? :(
can work one, its a little tricky only
anyway fellow acro s users,
does your phone lags after the phone heats up ?
ProzFromHell
hi guys, i know i might be digging this thread, but can someone tell me overall is this phone good?
i feel like changing a phone soon, and with a tight budget in hand, my only choices are samsung galaxy s2 and this sony xperia acro S.
cant decide between this 2 and some of my friends are saying sony phones are not too reliable wor. so how ar?
actually between this and Sony xperia S, which one better? and do ppl actually buy screen protector for this model?
thanks for any kind assistance
rssd21
Go for acro s. It is better than xs for its water-resist qualities and better buttons. Also, sony software is generally more stable than competitors.
I dont know what your friends are saying, myself now usinf both xs and gs2. Design aside, sony is still performing better in real life.
ProzFromHell
thanks for the reply. actually the reason why my friend say Sony is not reliable is because of the company's stability >_>
it sulks if i spend money to buy a phone, then within months the company go bankrupt or something
and, how bout the screen protector? how come like so little info bout screen protector over the internet?
rssd21
No problem for sony, they will only downsize when times are bad. They will not close down. Go google sony and you know they are doing big businesses in many industries.
For sp, its usually hard to find in local. You have to rely on online stores or official retailers.
pker88
try ask dataflex they might have SP
plus they also offer custom cut SP
they are located at AMK hub and jurong jcube
rssd21
I remember one user reported dataflex custom made sp is not good. Not sure about the jcube one though.
pker88
ya usually custom made is not as good as pre made
for specifc models
but if really need SP then got to look for alternative or online
or fly to jp
kentgh
for specifc models
or fly to jp
You can get the SP Amazon JP, which is where I got mine. You can search for Acro HD, which is jap version of Acro S.
Amazon.co.jp: Acro HD SP
Or you can just get a case (if you don't mind the extra hole) that comes with a free SP. :D
pker88
another way is here
Martin Fields Overlay Plus Screen Protector (Sony Xperia Acro S)
