Yen Exchange Rate Watch
Tormented Soul
Changed 12.43, Chinatown.
Not much difference if 2k. Travel all the way there to change transport fare also more expensive liao.
jnashville
Today's rate should be around 12.45 in the noon.
SGD $2k for rate 12.50 vs 12.40 is SGD $16 diff.
1000/ 12.50 = 80Yen per $1 SGD
SGD $2K * 80 = 160,000
1000/ 12.40 = 80.645 per $1 SGD
160,000/ 80.645 = $1984
Unless u changing more than $2k, waiting for Yen to drop much more than 12.40 or stay/work near arcade.
Change half will save you $8 but u got to monitor Yen movement and able to reach arcade and change before there's any movement.
Does the $8 saving worth?
Hi wanna clarify on the calculations. So the lower the exchange rate the better? Meaning 12.4 is better than 12.5?
Because i always baht and ringgit is higher the better example ringgit, 2.8 compare to 3.15, definitelt 3.15 is better.
So this yen exchange rate is yen to sgd and not sgd to yen ya? Hmm buy why not use the other way which is example exchange rate 80, so just use 1sgd x 80..
nemo88
Yup lower the better.
Don't know why they don't use the 80 figure, ask the money changers haha
Probably because currencies like USD, EUR, JPY are the global reference currencies and better to manage across platforms using that as the base instead of SGD.
lookingahead
Thanks for the clear explanation. :)
nemo88
The ones at Clementi central are not bad. Either basement of Clementi mall or inside Cityvibe. There's also one outside next to Citvibe.
freeman5js
03-03-2017 (345pm)
Just changed at arcade.
12.395
the best rate out of all the money changer, 345pm , 03-03-2017
