Zotac GPU
SGJoe86
All manufacturers will void warranty. But that is the only way to cool it better.
EVGA honors the warranty even when the sticker on their GPU is removed, as long as the card is not damaged by user. The idea of warranty is to protect buyers against manufacturer defect, not from users' own clumsiness in handling the product.
NMSS_2
No. If the product is defective, they would first check if the item was tampered. They would then reject RMA for that product.
The sticker is there for that purpose.
Koenig168
No, you can swap out and replace the HSF for EVGA and they will still honor the warranty.
watzup_ken
The warranty sticker goes both ways, to prevent tampering by retailer and owner. If you damage the card while meddling with it, no warranty will cover that.
SGJoe86
looks like evga is kinda odd one. I am assuming now that they dont have tamper sticker.
https://forums.evga.com/FindPost/2754079
There are still ant-tampering sticker on their screws from my recently purchased 1080. They will honor the warranty as long as it is returned to them with all original accessories attached to the item. For those running LC, that meant fixing back the original air cooler with the original screws; losing any items and yes, they can void your warranty.
NMSS_2
Good to hear that. It will be within my buy brand catagories for graphics card.
Unic0rn
likely cause is because my fans start to spin only at 60c, I have been trying to use msi afterburner software to control the gpu fans but is unable to enable that option. it was greyed out, what does that means?
meanwhile i temporarily resolve by using an old school method of air conditioning and external room fan to introduce cool air into the casing.
You can't compare it this way. There are many factors that will affect temps, regardless if the GPU is cooled by a massive heatsink or not. For example, the fan may be spinning slower to reduce noise (typical of MSI), or the ambient temps in your case, etc.
shadow84
Download zotac gpu software instead.
Audiology93
I am using msi gpu, will other’s software work with it? �
Yes. Can use any of them like evga precision, msi afterburner or firestorm. I've tried both afterburner and firestorm on my zotac GPU and it works.
Sent from HUAWEI Mate 20 using GAGT
trento
Almost impossible to tell damage unless it’s physically damaged
fi5hbone
I am using Zotac 1080 mini. No overclocking and temps are reasonable as well. Even when rocking games on a 4k screen, 60Hz. No major issue with it if you are not an overclocker.
Unic0rn
watzup_ken
I am not sure if you are using a GPU from MSI? If so, then the fan will indeed kick in at 60 degs. To be honest, if the heat is not causing it to throttle or hang, there is no need to worry. I leave it to the software to determine the speed of the fans.
Take note that when using external fan to blow into the casing, you are introducing a lot of dust into it. I did that once in the past and after sometime there is a lot of dust in there. Even without the fan, as long as the casing is open, it should be cool enough since the hot air don't recirculate in the casing.
Unic0rn
thanks for advice, I have on-screen overlay to monitor utilization, temps and fps. by the time the fans kick in at 60c is too late the temps will continue to climb to high 60s before stabilizing at 67 (air conditioning) or 77 (room temperature)
because when gaming at night after work I only have 1-2 hours and I usually switch on air conditioning.
when gaming the temps really increases from 40s to 60s like no one business (makes me want to put the cpu in the freezer)
definitely does not thermal throttle but I can see the temps and the fans are just beside ): I can see lol
watzup_ken
Don't worry man. The hardware is meant to take that kind of heat. I mean if you are using the air conditioning to cool yourself primarily, then that is not an issue. However if you are switching it on because of your concerns about the GPU temps, then you really don't have to. Like I said, they are built to withstand such temps, and you don't have to treat them like a person. ;)
Unic0rn
😄 I like u 👍🏼 不要看 😜
