ZTE Axon 7
n_bennyhk
Axon 7 comes with 2 Years Warranty
(Warranty against manufacturing defects by reason of faulty workmanship or internal electronic parts/ materials.*subjected to terms and conditions)
1st time glass replacement free on 1st year.
1st time water damage replacement on 1st year.
60 days 1 to 1 exchange for manufacturing defects.
Lasdax
Looking at Axon 7 to replace my Note 7 as a temp phone till Sammy comes out with Note 8, if there is going to be one after all these N7 problems.
How much is it selling here...I am looking at buying from China, Axon 7, Grey, 4GB Ram and 128GB ROM for about US$455 (abt S$640) free shipping.
SGD699 64GB 4GB
Sent from ZTE A2017G using GAGT
jkohlc2
Will it be voided if bootloader is unlocked?
Sent from Leica M240 using GAGT
White Shader13
Hi guys, anyone having issues connecting to the 4G network?
My Note 7 shows me on 4G+ but my axon 7 shows 3G with the data arrows then 3G again above the signal strength indicator...:s11:
sparhawk699
support spare part easy to get for this model ? btw which site you ordering from ?
Not sure about support spare parts, but China warranty, and I suppose you can send to Sim Lim, those people there repairing all quite good.
I use Ali Express
Snowblind
Hi guys how is the reception of the hp? Saw reviews where the wifi and reception is strong compare to other hps. Also where to get good covers for the hp? Thinking of getting for my wife. Thanks
sparhawk699
Are you guys using it naked or with screen protector, if so, where to get screen protector and which one is good?
Lasdax
Screen protector can get from taobao. And ship thru ezbuy or other forwarder.
I rmb seeing some1 sae that the shop in marina is bring in screen protector
Lasdax
Previously using Nexus 6 and the connectivity seems like no diff. Casing might have to get it oversea. Should be quite difficult to get locally
White Shader13
The set comes with a TPU case which u can use. Screen protector i got a film one from the seller. Note that the screen is also 2.5D at the sides, if glass won't have full coverage.
Another thing is the phone in SG warranty covers screen replacement in the first year. Hence can afford to use naked if you are comfortable
