ZTE Axon 7
porcu
yeah, agreed. How do you know US phones doesn't have? :)
Internet isn't safe. Need to remember that.
garychengjw
What is the latest firmware for the local Axon7?
Mine still at ZTE A2017GV1 0.0B05
Read that some has gone above that. Where did you manage to download the new firmware?
Stable?
back on axon7. anyway mine is b02. any way to force update to latest?
siewmai or hargow
Manually apply the update
http://www.ztedevice.com/support
Select 'Singapore' as country and "Axon 7" as model. download the update package on your PC. Unzip the package and copy the file 'update.zip' to the root of your micro SD card. Insert the SD card back into your axon 7 and go to setting n update. Should detect it. Or if it doesn't, enable OEM unlocking and boot into recovery mode. Shutdown the phone, turn it on by pressing the power button and the volume up button. Go to "apply update from SD card" then select file name "update.zip" you phone should start updating. Singapore ish B05, but there's B06 available. Some have the links in other forms like XDA and reddit
Sent from A Bottle Of Knee Gel using GAGT
The adups is in the China model only, ZTE USA did make a statement that US models don't have it, dk about global models
siewmai or hargow
Nope. But its best to backup to SD card. Open app "WeShare" go to backup and restore. Backup both on app and data on SD card. If you are unlucky and your. Phone Kanna data wipe, just open "weshare" go to backup and restore, and tap on restore apps and restore data. The restore function is only usable if u backup to SD card
garychengjw
whats your current version?
GreenHorn
