ZTE Axon 7
cyrilng
Not too sure. Try rebooting
If still can't try clearing cache partition
Btw, your Google apps come pre-installed or you have to install them yourself?
Sent from A Bottle Of Knee Gel using GAGT
Tried hard reset twice already.
Came with PlayStore app but when I first clicked on it, it wouldn't work. Then tried installing my gmail account and it prompted me to enable Google Play Services which was not in the app list originally but it only showed up when I tapped on 'Enable Google Play Services'. After that, it just goes get stuck on 'Checking Info".... :(
Tried downloading and installing the Playstore apk as well but still to go.
siewmai or hargow
Google play services isn't an app, you got time the checking info? Mine took quite a long time like 3-4 minutes
GreenHorn
The other way
USA model gets more support
Ah..I think this is due to hardware which is supposed to be the same across the global models.
The software seriously feels wierd..There are many apps which always crash which I don't encounter when I use my previous phones (all running Android 6.0.1) and some apps does not have any notification (I.e. nine email app). Hopefully their nougat version can address it.:(
Sent from ZTE A2017U using GAGT
cyrilng
Managed to do the mod so that my phone's hybrid microSD/nano SIM tray can hold 2 SIMS as well as a microSD card at the same time. :D
