i cant even finish 50gb locally, more data is not even enticing .. more roaming data and location is and free IDD roaming calls600GB -> 1 TB
will this increase entice more people?
1 TB roaming data for 365 daysi cant even finish 50gb locally, more data is not even enticing .. more roaming data and location is and free IDD roaming calls
Pay for IDD calls or use whatsappCan you guys make international calls or call Malaysia numbers from Zym?
I’m still having trouble with activating my iMessage and FaceTime with the mobile number. Got the same reply with the cso, tried everything and still not working.I’m also facing iMessage/FaceTime activation issue since I ported over to ZYM on 18 May 2025.
Contacted CSO through WhatsApp this morning and got a reply in the afternoon. Tried what was stated in the reply but still no go.
So after 3 hrs and turning back on iMessage/FaceTime and still not working after about 30mins, I rebooted the phone and was prompted to turn on iMessage/facetime. Select turn on and I check back about 30mins later and both activated.
Hopefully it helps those facing same issue though not sure if u need to inform and give cso your number.
Waa very good… they nev reply my msg but i tried this… turn off imessage/facetime last night. This morning turn on again and less than a min both activated.. finally!I’m also facing iMessage/FaceTime activation issue since I ported over to ZYM on 18 May 2025.
Anyone sign up online before 31 May and collect SIM card and port in after 1 Jun? Is the free 6 month still valid? Seems so from the T&C.
For China, must manually select network to, China Unicom or China Telecom.Feedback on Zym's roaming
Japan, Kyushu : works well!
China, Guilin: cannot connect at all.
Zym whatsapp is also totally unresponsive when I feedback on the lack of data roaming in China
Hmm.. That's strange. I will always see,Only CMCC and China Broadnet showed up when I tried to manually select.
When i reached out via WhatsApp, total silence, even till now. My poorest experience with Zym to date. Previously their whatsapp was responsive when I wanted to upgrade plan.
I'm using a S21U.
where you hear that Zym is going to offer VOLTE roaming calls?1 TB roaming data for 365 days
roaming calls coming soon, but only countries which have shut down 2G and 3G and launched VoLTE
msia no plan to shut down 2G, so no roaming call anytime soon
insider news, and it's not just zymwhere you hear that Zym is going to offer VOLTE roaming calls?
i also no insider news.insider news, and it's not just zym
(where's my insider tag?)
Thanks for sharing.Previously when I was using GOMO (Singtel’s MVNO) in China, Chengdu city was still ok, went up to 九寨沟, 黄龙雪山, all no network at all. Manually select also no use. I suspect Singtel’s MVNO in rural areas don’t work as well. I was stunned, my colleague’s SingTel no issues.
zym only has unicom and telecom for roaming, and telecom is inferior compared to china mobile or unicom, so default will always latch to unicom.Thanks for sharing.
But still I'm still puzzled (till now), why my mother-in-law's Redmi Pro got connection (China Unicom) even in 黑龙江 while my wife and I (both of us using S25U) cannot get any connection at all!
Thank you for your advice.zym only has unicom and telecom for roaming, and telecom is inferior compared to china mobile or unicom, so default will always latch to unicom.
I suspect your own phone has not turned on the data roaming setting, since it works when you put the sim in another phone, plus you were able to latch on to the network but unable to use data.
Only singtel can check what exactly is the issue when you are roaming with zym, which is an unfortunate disadvantage when using MVNO to roam
