[Maylyn - Networking] ASUS RT-AC88U
sigurros
Hi users of AC88,
Am upgrading from the asus ac68 to ac88.
May I asked how do you guys transfer the settings from the 68 to 88? Or is this possible at all?
Is the configuration file saved from the 68 able to be loaded to the 88?
Or need to setup the 88 from scratch?
As have quite a number of Port forwarding and configuration.
TIA.
Cheers.
renfred89
Hi users of AC88,
TIA.
Cheers.
You need to start from scratch. Uploading a config file from another model will only cause instability issues..
itdesign
Just bought the RT-AC88U.
It was good for few days. Suddenly the 5ghz wifi connection starts to dropped very badly.
Did a factory reset, first few hours ok, then dropped again.
Speedtest shows 150-300mbps download, but can dropped to below 100mbps.
And I'm doing speedtest via wifi just next to the router.
I'm on 1gbps Starhub, direct lan to modem is good connection at 960mbps average.
As for 2.4ghz, its consistent connection but of cos its lower speed.
localITguy
Suspended
i have just recontracted and got a ac88u can anyone verify that it support ddwrt ?
localITguy
Suspended
guys i am only getting 40mbps when i am right beside the ac88u (iphone here 2.4ghz)
something is wrong, did a reset via the UI and have changed to the best channel avaliable..
any advise?
xonix
any advise?
Which iPhone (?)
localITguy
Suspended
hopefully someone can shed some light. :(
anyone has the link to download the stock ac88u firmware so i can try to re-flash and see if it fixes the issue?
renfred89
I thought Port 4 is Mio TV only? Just upgraded from RT87U to RT88U. Planning to use the RT87U on my second level as an access point.
Port 3 can also be configured to support singtel tv under manual setting.
renfred89
The stock firmware is on asus support website leh..
localITguy
Suspended
i give up on my weak 2.4 Band issue only 30-40mbps even when i am near the router.
my old N56U, is able to hit at least 70mbps..
if anyone knows what is the problem or has the same issue as me, do drop me a PM.
ASUS@SG do Pm me if you could provide some assistance.
very very very disappointing, i always had good luck with ASUS routers
even my old N56 performs better over the ac88u, money wasted i guess
pepeEL
Hi
I have a question... why Asus dont want implement configuration vlan as netgear and other manufacturer?
wilflare
those coming from 68U - how is it?
anyone tried Double WAN on this?
thinking of using Double WAN using both MR + StarHub 1Gbps
(is there anyway to combine and get 2Gbps and keep my MR StaticIP)
a562140
From Asus android app system monitor:
Cpu1 at 100%... Is this normal?
Sent from Samsung SM-G930F using GAGT
Yellowfin
Deluxe Member
For this router, can we create our own password for the wps key or have to use the wps key provided by the manufacturer.
