Huawei Mate 8 - The True Successor
kyleongwl
guys i had just started to use huawei mate 8 as my 1st android phone... had enough of apple ios nonsense.... but theres 1 thing that is still bothering me... as in when i plugged my mobile into my pc, the HiSuite (default huawei app) did not give me an option to transfer music over from pc to my mobile... any solution to this problem?
when pc detect phone, shd open with win explorer...afterwhich just tranfer frm pc to phone (perhaps into music folder to be mo org
hyourinmaru
Is that sh*t method even working in the 1st place? I dun even see any folders from my huawei nxt-L29
benny888
When you connect phone to pc by default is charging state. Drag down status bar n choose USB connection as MTP or Files
Than you can see all your folders on the phone
azarel
care to show!
Ha sorry for slow reply...you can see the side 2 side comparison in size... the current casing i'm using is spigen rugged armour.
Sent from NVIDIA SHIELD TABLET using GAGT
jazzman80
by the way,
how can I disable the lockscreen?
I want to access the homescreen once the display lights on.
can't see any option
Ivy5TUH.png:
rharish_21
Can any bro confirm that we can change the navigation buttons order in Mate 8? I am also using Note 4 so i would prefer to keep the key layout same as Running Apps, Home and Back.. Possible to change?
benny888
Yes. You have few choices at settings/smart assistance/navigation bar
rharish_21
Just one more clarification.. Can we install a custom font without rooting? Like Samsung.. I need a specific font to be installed to read document in my native language..
warr
where do you guys get Mate 8?
through which telco at which plan is the best?
or you buy the phone only?
