Recommend a Good and Cheap Air-Con Service Company
empirestrike
if the drain pipe is installed correctly with the calculation of slope then still need to do maintenance? i am not talking about dust at the fan coil. i am talking about back flow of water from the drainage pipe and now water flow out from the compressor side
u r hdb? if the problem can be solve after u do the vacuum of the drain pipe.. 100% inside the drain pipe choke by dust n dirt. outdoor water leaking another problem oreli....
empirestrike
Hi,
Wonder any bros can help me with this?
My Mitsubishi electric inverter's vane always auto close up after a couple of hours but its still on, leaving the cold air coming out straight down...
Does anyone know what is wrong? :(
Thanks!
the swing put it to manual mode...:s22:
Orr_Bi_GoOT
Need advice on increasing the number of aircon in my house.
Currently have a mitsubishi sys-1 (invertor) aircon in one room. 3 years old. intend to install another aircon in my other room. (3-room flat).
What would be the most cost effective way of doing this?
Any good air con company does such services?
Thks in advance.
xxxjorxxx
Hi,
Thanks!
Dew prevention
During COOL or DRY operation with the vane angle at Angle 4 or 5 when the compressor’s cumulative operation time exceeds 1 hour, the vane angle automatically changes to Angle 1 for dew prevention.
http://www.mitsubishielectric.com.sg/services-support/faqs
bundy
Any reliable contractor to dismantle the entitled fan coil for cleaning?
Sent from OMG it's Nexus using GAGT
goodhome
Hi Bro,
Try calling Aircon Republic Pte Ltd, I am using them very efficient and friendly. You can do more research on them online to decide if you want to use them.
I personally left my 10 years servicing aircon vendor due to OVER PRICED services.
Cheers :)
empirestrike
Thks in advance.
yr home hv aircond ledge?:s11:
ipaq4444
yes, hdb.
after i vacuum, the aircon became colder but the water still leak at my compressor side.
if outdoor water leak, what problem is that?
empirestrike
yes, hdb.
outdoor sure have some water drip cause by condensation...... if yr unit below complaint u need to add 1 water tray...
maisatomai
can recommend me a good aircon service company. The only one i saw in this thread is those low post count promoting their own service
maisatomai
Hi Bro,
Cheers :)
out of 10 posts, 8 of your posts is advertising for this Aircon Republic Pte Ltd. Like that how to trust?:s22::s22:
only_lonely
Any idea the root cause of water dripping sound (15mins interval)???
Just reno bathroom and the worker remove the L shape pipe in toilet which is installed preciiusly to let the water flows out till drain side.
Since after that, the sound is heard during night when turn on aircon. Weird things it is more frequent when the aircon in swing mode.
Will it posibble the pipe broken somewhere when worker try to hack n dismate the pipe? Any idea is aircon cleaning service able to help on this?
Orr_Bi_GoOT
Thks in advance.
The only aircon ledge in my 3 rm flat is used by the original sys-1 aircon.
Some one quoted me 1800+ to add a fancoil to my existing condenser plus the other new aircon, the old one remain. You all think its worth? If i change the whole thing, i.e. completely new sys-2, he quoted me 2400+.
Or should I just get a portable aircon for the other room?
empirestrike
i think the worker oreli remove and conceal yr drain pipe to the floor trap inside yr toilet... dripping water sound quite normal...
empirestrike
picture pls... u open yr window and take alook outside outdoor unit.. from yr view sure u can see the space enough for 1 more condenser unit.:D
recommend add 1 more SYS 2 aircond with only 1 fancoil.. Old one remain... if old one spoil u can just relocate the outside piping n can use for both room...:s12:
deliFury
this place is like ocean swimming with sharks. my AC is due for servicing and i can't even find a reliable recommendation in any forums.
