[Maylyn - Networking] ASUS RT-AC88U
evildoctor
How come everybody are getting problems with firmware 3341? So far, i have not encountered any big issues. Hopefully it stays that way.
Ckrono
Anyway guys, I posted earlier about downgrading from 3341 to 2345 using MyRepublic ISP.
A few minutes ago, my wired Internet connection went dead. Lights on AC88U are all on, but I received "DNS Server could not be reached" when visiting websites, accessing the router UI gives me "Settings has been updated. The web page will now refresh" and wifi speeds slow to a crawl (Ping test 500++ ms), I tried switching off the router and turning it on, restarting my computer. Still down for my wired connection. Noticed that the internet led is red after restarting the router.
I tried to hard reset the router and now everything works fine. This is driving me crazy I'm not sure what's causing my router to suddenly spike in ping and disconnect my wired connection. I tried disabling and enabling the adapter too but it didn't work.
After the hard reset, I made some changes in settings, such as Auto Logout to 0 (default 30), turned off Reboot Scheduler and Wireless Scheduler, turned off QoS and WPS, changed channel frequency, SSID name and password, router login name and password.
I am really not sure what is crashing my router now that I've downgraded to firmware 2345. I'll paste a log from after hard resetting my router, hopefully someone knows what happened. Any help will be greatly appreciated.
I have no USB Disks connected and I have 1 wired connection, 1 wired powerline connection and 4 wifi clients (phones)
EDIT: Read somewhere that DHCP Query may cause lease problems causing router to reboot every 4hr. I noticed my disconnects to be about 4hrs apart too. Have changed to Normal mode and will monitor, if fail I will probably try disabling NAT Acceleration last (I doubt MyRepublic needs to disable this..) before calling ASUS/MyRepublic for help. I'm sure my problem is configuration side.. Goodnight!
Code:
Aug  1 00:00:20 syslogd started: BusyBox v1.17.4
Aug  1 00:00:20 kernel: klogd started: BusyBox v1.17.4 (2016-02-25 10:57:39 CST)
Aug  1 00:00:20 kernel: Linux version 2.6.36.4brcmarm (ham@xpdev) (gcc version 4.5.3 (Buildroot 2012.02) ) #52 SMP PREEMPT Fri Feb 26 17:02:36 CST 2016
Aug  1 00:00:20 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Aug  1 00:00:20 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug  1 00:00:20 kernel: Machine: Northstar Prototype
Aug  1 00:00:20 kernel: Ignoring unrecognised tag 0x00000000
Aug  1 00:00:20 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug  1 00:00:21 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Aug  1 00:00:21 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug  1 00:00:21 kernel: Memory: 515036k/515036k available, 9252k reserved, 0K highmem
Aug  1 00:00:21 kernel: Virtual kernel memory layout:
Aug  1 00:00:21 kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Aug  1 00:00:21 kernel:     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Aug  1 00:00:21 kernel:     DMA     : 0xf7e00000 - 0xffe00000   ( 128 MB)
Aug  1 00:00:21 kernel:     vmalloc : 0xa0800000 - 0xf0000000   (1272 MB)
Aug  1 00:00:21 kernel:     lowmem  : 0x80000000 - 0xa0000000   ( 512 MB)
Aug  1 00:00:21 kernel:     modules : 0x7f000000 - 0x80000000   (  16 MB)
Aug  1 00:00:21 kernel:       .init : 0x80008000 - 0x80050000   ( 288 kB)
Aug  1 00:00:21 kernel:       .text : 0x80050000 - 0x803f1000   (3716 kB)
Aug  1 00:00:21 kernel:       .data : 0x8040a000 - 0x8042e400   ( 145 kB)
Aug  1 00:00:21 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06, pc=0x8000f9b8 lr=0x8000f9ac ignored.
Aug  1 00:00:21 kernel: Mount-cache hash table entries: 512
Aug  1 00:00:21 kernel: CPU1: Booted secondary processor
Aug  1 00:00:21 kernel: Found a Zentel/Esmt NAND flash:
Aug  1 00:00:21 kernel: Total size:  128MB
Aug  1 00:00:21 kernel: Block size:  128KB
Aug  1 00:00:21 kernel: Page Size:   2048B
Aug  1 00:00:21 kernel: OOB Size:    64B
Aug  1 00:00:21 kernel: Sector size: 512B
Aug  1 00:00:21 kernel: Spare size:  16B
Aug  1 00:00:21 kernel: ECC level:   8 (8-bit)
Aug  1 00:00:21 kernel: Device ID: 0xc8 0xd1 0x80 0x95 0x42 0x7f
Aug  1 00:00:21 kernel: ACP (Accelerator Coherence Port) enabled
Aug  1 00:00:21 kernel: bio: create slab <bio-0> at 0
Aug  1 00:00:21 kernel: PCI: no core
Aug  1 00:00:21 kernel: PCI: Fixing up bus 0
Aug  1 00:00:21 kernel: PCI: Fixing up bus 1
Aug  1 00:00:21 stop_nat_rules: apply the redirect_rules!
Aug  1 00:00:21 WAN Connection: ISP's DHCP did not function properly.
Aug  1 00:00:22 kernel: VFS: Disk quotas dquot_6.5.2
Aug  1 00:00:22 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug  1 00:00:22 dnsmasq[480]: warning: interface ppp1* does not currently exist
Aug  1 00:00:22 RT-AC88U: start httpd
Aug  1 00:00:22 kernel: pflash: found no supported devices
Aug  1 00:00:22 kernel: bcmsflash: found no supported devices
Aug  1 00:00:22 kernel: Boot partition size = 524288(0x80000)
Aug  1 00:00:22 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Aug  1 00:00:22 kernel: nflash: squash filesystem with lzma found at block 29
Aug  1 00:00:22 kernel: Creating 4 MTD partitions on "nflash":
Aug  1 00:00:22 kernel: 0x000000000000-0x000000080000 : "boot"
Aug  1 00:00:22 kernel: 0x000000080000-0x000000200000 : "nvram"
Aug  1 00:00:22 kernel: 0x000000200000-0x000004000000 : "linux"
Aug  1 00:00:22 kernel: 0x0000003b3950-0x000004000000 : "rootfs"
Aug  1 00:00:22 kernel: === PPTP init ===
Aug  1 00:00:22 kernel: Registering the dns_resolver key type
Aug  1 00:00:22 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Aug  1 00:00:22 kernel:  2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Aug  1 00:00:22 kernel: Available 7 bytes at (off,len):
Aug  1 00:00:22 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Aug  1 00:00:22 kernel: Options: NO_AUTOINCR,NO_READRDY,
Aug  1 00:00:22 kernel: Creating 1 MTD partitions on "brcmnand":
Aug  1 00:00:22 kernel: 0x000004000000-0x000008000000 : "brcmnand"
Aug  1 00:00:22 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Aug  1 00:00:22 kernel: rtl8365mb: module license 'Proprietary' taints kernel.
Aug  1 00:00:22 kernel: Disabling lock debugging due to kernel taint
Aug  1 00:00:22 kernel: rtl8365mbrtl8365mb initialized(0)(retry:1)
Aug  1 00:00:22 kernel: rtk port_phyEnableAll ok
Aug  1 00:00:22 kernel: register rtl8365mb done (link down at first)
Aug  1 00:00:22 kernel: et_module_init: passivemode set to 0x0
Aug  1 00:00:22 kernel: et_module_init: txworkq set to 0x0
Aug  1 00:00:22 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug  1 00:00:22 kernel: et_module_init: et_rxlazy_timeout set to 0x3e8
Aug  1 00:00:22 kernel: et_module_init: et_rxlazy_framecnt set to 0x20
Aug  1 00:00:22 kernel: et_module_init: et_rxlazy_dyn_thresh set to 0
Aug  1 00:00:22 kernel: fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.32 (r608473)
Aug  1 00:00:22 kernel: fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.32 (r608473)
Aug  1 00:00:22 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.32 (r608473)
Aug  1 00:00:22 disk monitor: be idle
Aug  1 00:00:22 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Aug  1 00:00:22 kernel: PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
Aug  1 00:00:22 kernel: dhd_attach(): thread:dhd_watchdog_thread:175 started
Aug  1 00:00:22 kernel: CUR_ETHERADDR : 6
Aug  1 00:00:22 kernel: f8 32 e4 52 1d 50
Aug  1 00:00:22 kernel: Dongle Host Driver, version 1.363.45.52 (r608479)
Aug  1 00:00:22 kernel: Compiled in drivers/net/wireless/bcmdhd on Feb 25 2016 at 11:19:23
Aug  1 00:00:22 kernel: Register interface [eth1]  MAC: f8:32:e4:52:1d:50
Aug  1 00:00:22 kernel: PCI: Enabling device 0002:01:00.0 (0140 -> 0142)
Aug  1 00:00:22 kernel: dhd_attach(): thread:dhd_watchdog_thread:179 started
Aug  1 00:00:22 kernel: f8 32 e4 52 1d 54
Aug  1 00:00:22 kernel: Register interface [eth2]  MAC: f8:32:e4:52:1d:54
Aug  1 00:00:22 kernel: Empty flash at 0x021b6f28 ends at 0x021b7000
Aug  1 00:00:22 kernel: JFFS2 notice: (399) check_node_data: wrong data CRC in data node at 0x021b5ee4: read 0xee1a392f, calculated 0x47191446.
Aug  1 00:00:22 kernel: rtk port_phyEnableAll (on) ok
Aug  1 00:00:22 miniupnpd[525]: version 1.9 started
Aug  1 00:00:22 miniupnpd[525]: HTTP listening on port 43457
Aug  1 00:00:22 miniupnpd[525]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 00:00:22 syslog: Generating SSL certificate...
Aug  1 00:00:23 kernel: dhd_detach(): thread:dhd_watchdog_thread:179 terminated OK
Aug  1 00:00:23 kernel: dhd_detach(): thread:dhd_watchdog_thread:175 terminated OK
Aug  1 00:00:26 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Aug  1 00:00:26 kernel: dhd_attach(): thread:dhd_watchdog_thread:259 started
Aug  1 00:00:26 kernel: CUR_ETHERADDR : 6
Aug  1 00:00:26 kernel: f8 32 e4 52 1d 50
Aug  1 00:00:26 kernel: Dongle Host Driver, version 1.363.45.52 (r608479)
Aug  1 00:00:26 kernel: Compiled in drivers/net/wireless/bcmdhd on Feb 25 2016 at 11:19:23
Aug  1 00:00:26 kernel: Register interface [eth1]  MAC: f8:32:e4:52:1d:50
Aug  1 00:00:26 kernel: dhd_attach(): thread:dhd_watchdog_thread:25d started
Aug  1 00:00:26 kernel: f8 32 e4 52 1d 54
Aug  1 00:00:27 kernel: Register interface [eth2]  MAC: f8:32:e4:52:1d:54
Aug  1 00:00:35 wan: [wan0_hwaddr] == [F8:32:E4:52:1D:50]
Aug  1 00:00:36 syslog: module ledtrig-usbdev not found in modules.dep
Aug  1 00:00:36 syslog: module leds-usb not found in modules.dep
Aug  1 00:00:36 kernel: SCSI subsystem initialized
Aug  1 00:00:36 rc_service: udhcpc 663:notify_rc start_firewall
Aug  1 00:00:36 wan: finish adding multi routes
Aug  1 00:00:36 rc_service: udhcpc 663:notify_rc stop_upnp
Aug  1 00:00:36 rc_service: waitting "start_firewall" via udhcpc ...
Aug  1 00:00:36 WAN Connection: WAN was restored.
Aug  1 00:00:37 kernel: reset usb phy..
Aug  1 00:00:37 stop_nat_rules: apply the redirect_rules!
Aug  1 00:00:38 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 00:00:38 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 00:00:39 rc_service: udhcpc 663:notify_rc start_upnp
Aug  1 00:00:39 rc_service: waitting "stop_upnp" via udhcpc ...
Aug  1 00:00:39 miniupnpd[525]: shutting down MiniUPnPd
Aug  1 00:00:40 dhcp client: bound 172.23.134.23 via 172.23.128.1 during 3600 seconds.
Aug  1 00:00:41 miniupnpd[806]: version 1.9 started
Aug  1 00:00:41 miniupnpd[806]: HTTP listening on port 36959
Aug  1 00:00:41 miniupnpd[806]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 00:00:41 ntp: start NTP update
Jul 14 15:01:25 rc_service: ntp 805:notify_rc restart_upnp
Jul 14 15:01:25 miniupnpd[806]: shutting down MiniUPnPd
Jul 14 15:01:25 miniupnpd[814]: version 1.9 started
Jul 14 15:01:25 miniupnpd[814]: HTTP listening on port 54972
Jul 14 15:01:25 miniupnpd[814]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 14 15:01:26 rc_service: ntp 805:notify_rc restart_diskmon
Jul 14 15:01:26 disk_monitor: Finish
Jul 14 15:01:26 disk monitor: be idle
Jul 14 15:01:37 hour monitor: daemon is starting
Jul 14 15:01:44 crond[488]: time disparity of 502021 minutes detected
Jul 14 15:04:01 rc_service: httpd 486:notify_rc start_autodet
Jul 14 15:04:23 rc_service: httpd 486:notify_rc start_webs_update
Jul 14 23:04:56 syslogd started: BusyBox v1.17.4
Jul 14 23:04:56 kernel: klogd started: BusyBox v1.17.4 (2016-02-25 10:57:39 CST)
Jul 14 23:04:56 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jul 14 23:04:57 hour monitor: daemon is starting
Jul 14 23:04:57 hour monitor: daemon terminates
Jul 14 23:04:58 kernel: dhd_detach(): thread:dhd_watchdog_thread:25d terminated OK
Jul 14 23:04:58 kernel: dhd_detach(): thread:dhd_watchdog_thread:259 terminated OK
Jul 14 23:05:02 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jul 14 23:05:02 kernel: dhd_attach(): thread:dhd_watchdog_thread:42e started
Jul 14 23:05:03 kernel: CUR_ETHERADDR : 6
Jul 14 23:05:03 kernel: f8 32 e4 52 1d 50
Jul 14 23:05:03 kernel: Dongle Host Driver, version 1.363.45.52 (r608479)
Jul 14 23:05:03 kernel: Compiled in drivers/net/wireless/bcmdhd on Feb 25 2016 at 11:19:23
Jul 14 23:05:03 kernel: Register interface [eth1]  MAC: f8:32:e4:52:1d:50
Jul 14 23:05:03 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jul 14 23:05:03 kernel: dhd_attach(): thread:dhd_watchdog_thread:432 started
Jul 14 23:05:03 kernel: f8 32 e4 52 1d 54
Jul 14 23:05:03 kernel: Register interface [eth2]  MAC: f8:32:e4:52:1d:54
Jul 14 15:05:06 hour monitor: daemon is starting
Jul 14 23:06:45 rc_service: httpd 486:notify_rc restart_wireless
Jul 14 23:06:47 kernel: dhd_detach(): thread:dhd_watchdog_thread:432 terminated OK
Jul 14 23:06:47 kernel: dhd_detach(): thread:dhd_watchdog_thread:42e terminated OK
Jul 14 23:06:51 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jul 14 23:06:51 kernel: dhd_attach(): thread:dhd_watchdog_thread:4b0 started
Jul 14 23:06:52 kernel: CUR_ETHERADDR : 6
Jul 14 23:06:52 kernel: f8 32 e4 52 1d 50
Jul 14 23:06:52 kernel: Dongle Host Driver, version 1.363.45.52 (r608479)
Jul 14 23:06:52 kernel: Compiled in drivers/net/wireless/bcmdhd on Feb 25 2016 at 11:19:23
Jul 14 23:06:52 kernel: Register interface [eth1]  MAC: f8:32:e4:52:1d:50
Jul 14 23:06:52 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jul 14 23:06:52 kernel: dhd_attach(): thread:dhd_watchdog_thread:4b4 started
Jul 14 23:06:52 kernel: f8 32 e4 52 1d 54
Jul 14 23:06:52 kernel: Register interface [eth2]  MAC: f8:32:e4:52:1d:54
Jul 14 23:08:07 rc_service: httpd 486:notify_rc restart_wireless
Jul 14 23:08:09 kernel: dhd_detach(): thread:dhd_watchdog_thread:4b4 terminated OK
Jul 14 23:08:09 kernel: dhd_detach(): thread:dhd_watchdog_thread:4b0 terminated OK
Jul 14 23:08:14 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jul 14 23:08:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:54f started
Jul 14 23:08:14 kernel: CUR_ETHERADDR : 6
Jul 14 23:08:14 kernel: f8 32 e4 52 1d 50
Jul 14 23:08:14 kernel: Dongle Host Driver, version 1.363.45.52 (r608479)
Jul 14 23:08:14 kernel: Compiled in drivers/net/wireless/bcmdhd on Feb 25 2016 at 11:19:23
Jul 14 23:08:14 kernel: Register interface [eth1]  MAC: f8:32:e4:52:1d:50
Jul 14 23:08:14 kernel: dhd_attach(): thread:dhd_watchdog_thread:553 started
Jul 14 23:08:15 kernel: CUR_ETHERADDR : 6
Jul 14 23:08:15 kernel: f8 32 e4 52 1d 54
Jul 14 23:08:15 kernel: Dongle Host Driver, version 1.363.45.52 (r608479)
Jul 14 23:08:15 kernel: Compiled in drivers/net/wireless/bcmdhd on Feb 25 2016 at 11:19:23
Jul 14 23:08:15 kernel: Register interface [eth2]  MAC: f8:32:e4:52:1d:54
Jul 14 23:08:29 rc_service: httpd 486:notify_rc restart_wireless
Jul 14 23:08:30 kernel: dhd_detach(): thread:dhd_watchdog_thread:553 terminated OK
Jul 14 23:08:30 kernel: dhd_detach(): thread:dhd_watchdog_thread:54f terminated OK
Jul 14 23:08:34 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jul 14 23:08:34 kernel: dhd_attach(): thread:dhd_watchdog_thread:5c5 started
Jul 14 23:08:35 kernel: CUR_ETHERADDR : 6
Jul 14 23:08:35 kernel: f8 32 e4 52 1d 50
Jul 14 23:08:35 kernel: Dongle Host Driver, version 1.363.45.52 (r608479)
Jul 14 23:08:35 kernel: Compiled in drivers/net/wireless/bcmdhd on Feb 25 2016 at 11:19:23
Jul 14 23:08:35 kernel: Register interface [eth1]  MAC: f8:32:e4:52:1d:50
Jul 14 23:08:35 kernel: PCI_PROBE:  bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
Jul 14 23:08:35 kernel: dhd_attach(): thread:dhd_watchdog_thread:5c9 started
Jul 14 23:08:35 kernel: f8 32 e4 52 1d 54
Jul 14 23:08:35 kernel: Register interface [eth2]  MAC: f8:32:e4:52:1d:54
Jul 14 23:13:10 syslogd started: BusyBox v1.17.4
Jul 14 23:13:10 kernel: klogd started: BusyBox v1.17.4 (2016-02-25 10:57:39 CST)
Jul 14 23:13:11 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jul 14 23:13:11 miniupnpd[1561]: version 1.9 started
Jul 14 23:13:11 miniupnpd[1561]: HTTP listening on port 54953
Jul 14 23:13:11 miniupnpd[1561]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 14 23:13:12 hour monitor: daemon is starting
Oranger
Ohh crap, should have checked out this thread earlier. Just got this router yesterday and itchy-finger saw got new firmware, so just let it update.
As with quite a number here, having disconnection issues on both 2.4 and 5Ghz.. :(
xonix
Air and air2 at home.
You will probably see 100-200++ speeds on your air 2 due to support for 802.11ac. Do note, once your iPad air 1 joins the same 5 ghz Wi-Fi network, it will drop both devices to 802.11n speeds
ralfale
Do you meant to say WiFi speed will follow the slowest device in the same system?
xonix
It depends, 5 ghz has 20/40/80 mhz channels.
Basically both Wi-Fi n (max 40mhz) and ac devices support 40mhz. On the other hand, ac devices may or may not support 80mhz.
If your 802.11ac devices don't support 80 mhz, then you won't see a difference in speed.
xonix
Auto logout has no bearing on your disconnection. It refers to how long router will wait once user interface is idle before logging out of the GUI.
It's good to enable reboot scheduler as it allows the router to perform rubbish maintenance. Just set it to reboot when it's least likely to affect usage.
Seems like you are maybe facing issues with my republic dns server. You can try using other dns servers to see if it helps.
ralfale
Many thanks for your explanation!
Ckrono
Hey xonix. Thanks for answering. I came home a couple hours ago and my family told me wifi works perfect today, really damn happy. Turned on my computer and surfed the internet for a while with no problems but got disconnected again. I checked with family, no one was disconnected on wifi and my phone was connected fine too. I tried IPv4 DNS from Auto to 8.8.8.8 and rebooted my computer and it worked. But prior to that, I did an instant reboot and the connection didn't restore. Seems like you hit the nail on the DNS server but I'm clueless on what is screwing up my auto dns obtaining.
I gave a call to MyRepublic but the technician says this issue is weird because he never heard of such problem being solved by setting DNS server to google and settled. I'll monitor again my wired connection on the 8.8.8.8 DNS server.
Thanks, I will re-enable the scheduler if that's the case. Your reply is really appreciated! :D
kashix
xonix is right, MR DNS really cranky from time to time, have to manually switch to google's dns to get my internet back. Many times it just broke out of the blue ...
Ckrono
Hi guys, quick update..
Internet still dropping to ridiculous pings (3k-5k ms) or disconnected altogether sometimes (getting DNS Server could not be found/resolved too). Apparently it happens every few chunks of hours. Tested a direct connection to the MyRepublic ONT and connection is perfect with no drops. I strongly believe something is wrong with my router.
MR Tech will continue to monitor my connection and call me over the next couple days.
Will bring to Avertek tomorrow. Sigh..
ravener
Quick update on mine as well.
Router just bit the dust.
At around 2200h last night, the unit dropped all local connections, unable to connect back.
Status LED on the router only show the first 4: power, wifi, wifi 5Ghz and Internet. The LAN network LED is unlit.
Power recycling yielded no results, unit went into a boot loop. Doing a hard reset does not work either.
Looks like i gotta bring it in for replacement.
edit: weird ****, router seems to be overheating? set it aside for awhile while i was looking up service center address, turn it on just to reconfirm, and it boots up just fine again.
edit: so now it boots, but after the hard reset, i can't log in with admin/admin
Ckrono
Bro, I came back from Avertek today. The support guy there told me 3341 firmware is confirmed to give problems with the router and said not to upgrade to 3341 no matter what. Instantly gave me a new router. So far so good. Will be back to update again.
weng
I'm currently using N66U with 200M Singtel fibre. PC is just about 6-7m away with line of sight, using USB-N66 adapter.
Just got upgraded to 500M.
I'm thinking of upgrading router just to optimize the "foundation".
Situation is:
- 1 x PC being the main machine. Other devices utilizing are 3 x phones and 1 x iPad. 1 x laptop occasional.
- No NAS.
- No heavy usage. Just usual surfing.
- Somehow 5G coverage better than 2.4G in my house, so all devices on 5G.
- Full wireless usage at home. Due to whatever circumstances I won't be wiring up.
Considering between AC68 and AC88.
AC88 because even the 2.4G hits the 1G "milestone", which I foresee is the subscription I would eventually settle for without paying more for years to come. Hence "technically" I have covered all grounds. Understand the AC88 adapter still not available yet but that can come later.
AC68 as a minimum as the 5G would hit 1G and hence cater for it.
Now comes the key questions....
1) If I have the corresponding adapters (68 and 88 to so called establish the maximum link), at 1G subscription, will there be any improvement with AC88's 2167 Mbps link over AC68's 1300 Mbps link? Will the AC68's extra 300Mbps have enough buffer for real world throughput such that any/most losses are due to external factors (eg. internet servers) and not domestic connection limits?
2) If I eventually get to setup a NAS, will the AC88 have any benefit over AC68 based on my usage? Will the AC68's extra 300Mbps have enough buffer to cater for the NAS 1G connection such that any/most losses are between router and NAS and not due to the wifi connection limits?
