The Spectacles Thread. - Part 2
razorlala
wa wat kind of spects 1k sia. the kind can zoom anot? can see thru wall anot? got heat signature detector anot?
anot anot anot
Whitecamel
I also like Dita. But cannot afford.
Minty Mint
I was looking at this Dita Edmont. But I don't think I can pull it of this kind of design.
Chow Yun Fatt was wearing this in the movie "Cold War 2".
Gentle Monster Ray X D01.
Thom Brown.
razorlala
city square is spectacles monopoly. prices so damn high. but walao. i see u guys recommendation to spect shop. say simi KSL holiday plaza. i went KSL city dont have any of the spect shop u guys mentioned not too long ago.
then otw back see this building called holiday plaza...
tiny
Eyezen is an upgraded improved version makes yur eyes less tired!!! Best part is its cheaper! Lastime crizal must add $100 for prevenzia total i paid $570 for crizal prevencia RX. Now Eyezen has crizal + prevencia + eyezen features all in one RX lens only at $350!!! Damn worth it. Not going for zeiss and hoya anymore. Gotok us till gao gao.
EyeZen is $50 more. Very worth it considering you wear 365 days... $50 is nothing.
curo
EyeZen lens available in most optical shop? My hoya lens already cost me $500 and my degree is only 100+ on each side.. If EyeZen lens is good then I will not go for hoya..
Can eyezen add transition?
d3n
KSL city, yongming at the basement is not bad.
noobzpro
Dita range in sg not very good le. Alot models don't have. Think I will order online..
noinimod
Need the right face shape to pull off the circle type of frames. Saw a few people trying to pull off that look but doesn't look good on them cos of their face shape
nbhw_0987
I did not chose those $188 package frame, so my total cost is ard $268 with blue lens.
They are having those non $188 promo @20% discount, and 2nd piece @40% discount. You might want to check it out.
wat is the total cost after u add the blue lens upgrade?
paul02
Didn't last me a year and already the multi-coat coming off already. Previously had Crizal, lasted almost 3 years before that happened.
What is this multi-coating you speak of? Do you have a photo?
I purchased mine back in 2014, 1.60 with frame for $158. Really nice price.
My spectacles has no visible scratches but there seems to be something going on in-between the lens (could be wrong).
rootz
Anyone happens to know is there any sale for Oakley Crosslink (Asian Fit?)
Thanks in advance!
razorlala
bought blue whale lens and lee cooper half frame at rm660 from ban eyecare in holiday plaza.
good?
omglolz
Anyone knows where to make just the lens at a cheap price? I only have one pair of spectacles and usually they will need to take away the spectacles to make the lens right? (Other than owndays that can do it within 20mins but $198 for hi index is quite steep for me)
