1k rig
rollanddie
Just for some gaming... Dota2 and fps
Graphic card - 970
Psu - gold 550w fsp hexa+ [80 plus]
Ssd - 128/250gb Samsung
Ram - 8gb value ram ddr3
Hdd - 1tb wd blue
Casing - sharkon t28
Motherboard + processor - i54460
Windows - reddit
1k able to do @ PCThemes? (without monitor)
Any recommendations for motherboard?
Sent from Sony D6653 using GAGT
destiny88
Graphic card - 970
Hdd - 1tb wd blue
Windows - reddit
if you intend to get multi GPU next time better to go for RX480, dont get GTX970 pls.....
and get H97 motherboard also,no sli though but its cheaper and u dont overlock, still can crossfire with 2 AMD cards,
MSI gaming 3 if you want a premium board with m.2ssd slot, if not just get the MSI PC mate
localITguy
Suspended
get a cheaper board lah! like a entry level asrock board lah like an asrock H81 basic 1
then can spend more on a GPU or a higher cap ssd
rollanddie
well its quite simple though:
1) u can use a higher reso monitor if u got more rams.
2) as more games are quite heavy with those map textures and etc, gpu can just get those data cache to the its ram instead of relying on the system ram.
Oh i see i see. Thanks :o
Is 8gb sufficient for a ~1k resolution monitor? I'm doing light gaming like dota2 maybe some occasional fps games...
lalalalalala
rollanddie
Graphic card - 970 /RX480
Ssd - 128/250gb Samsung /transcend
Hdd - 1tb wd blue
Processor - i54460
Motherboard shortlisted a few - Asrock H81M-HDS /H97 /
Windows - reddit
updated in BOLD
any idea is it possible to get all this at $1k from PCThemes?
spiky0180
You don't need a H97 mobo. You won't use all the features now. Better to save the money and get better PSU/SSD/Casing.
Go with the RX480. Its a little bit more ex than a gtx 970.
SECTORTWO
This is my current parts list for a 1k rig (I help my friends choose parts for fun)...everything based on Fuwell's pricelist.
Intel Core i3-6100 - $147
MSI H110i PRO AC (M-ITX) - $149
Crucial PC4-1700/2133MHz DDR4 8GB - $47
AMD RX470 4GB - $269 (my estimate)
Sandisk Ultra II 240GB - $115
Seasonic S12II 520W - $89 (don't let shop uncle upsell you, got one of the guys always like to say that 520W not enough...when actually a SLI 1080 setup uses less than 500W at load apparently.)
Fractal Design Core 500 Mini ITX - $99 (can those really cheap shitty casing to fit budget too)
If you need more storage but not willing to sacrifice the price - Remove the SSD above and get Seagate Hybrid SSHD 2TB - $151
OS either get from Reddit or Kinguin.
MoneyFace =p
Graphic card - 970
Hdd - 1tb wd blue
Windows - reddit
A nice red and black themed PC. :evil:
CPU+MB: Intel Core i5-4460 + ASRock H81M-HDS R2.0 @ $330
RAM: G.Skill NT DDR3-1600 CL11 8GB [Black PCB] @ $52
GPU: AMD Radeon RX470 4GB @ ~$279
Price estimation based on current local RX480 price.
SSD: Transcend SSD220S 240GB @ $99+3 (Lazada SG)
HDD: Western Digital Blue 1TB @ $74
PSU: Seasonic S12G 450W [80 Plus Gold] @ $79
CASE: Tecware F3 [Red] @ $39+3 (Lazada SG)
OS: Microsoft Windows 10 Home 64-bit Product Key [OEM] @ $48 (Reddit)
Total: $1006
Buy others from PC Themes, #04-15.
All Lazada prices inclusive of delivery charge.
